Help with formating column in C1TrueDBGrid
Posted by: Victor.m.charles.civ on 26 February 2020, 12:46 pm EST
    Posted 26 February 2020, 12:46 pm EST
    After loading the Grid using a table from an xml file, how do I reformat a column (xxxx-xx-xxx-xxxx) to remove the “-” and only display (xxxxxxxxxxxxx)?
    Victor
  • Posted 27 February 2020, 4:38 am EST
    Hi Victor,
    You can use the FormatText event as implemented in the attached sample to achieve your desired output.
    I hope it helps.
    TrueDBGridReformatColumnDemo.zip
  • Posted 2 March 2020, 11:43 am EST
    It works.
    Thank You.
