Help with Highlighting rows with identical records using MultiSelect control
Posted by: Victor.m.charles.civ on 9 April 2020, 11:37 pm EST
    Posted 9 April 2020, 11:37 pm EST
    How do I modify the code below to replace a Grid control with a Multiselect control to highlight rows in another Grid. I need to highlight rows using both the “AND” / “OR” approach where selected fields contain two or more records in selected Field(s). The code below only uses the “AND” approach which requires combination of all selected fields have identical data in two or more records. For the “OR” approach, the records are highlighted when either selected fields have identical data in two or more records.
    Button_Click Event:
    yx = “”
    For Each Srow In Me.C1TrueDBGrid9.SelectedRows
    If vc1 > 0 Then
    yx = yx & “, " & “'” & Me.C1TrueDBGrid9.Columns(0).CellText(Srow) & “'”
    Else
    yx = “'” & Me.C1TrueDBGrid9.Columns(0).CellText(Srow) & “'”
    End If
    vc1 = vc1 + 1
    If yx.StartsWith(”,") Then
    yx = yx.Substring(1, yx.Length - 1)
    End If
    Next
    apply = True
    C1Screen1.Refresh()
    C1Screen1.FetchRowStyles = True
    Private Sub C1Screen1_FetchRowStyle(sender As Object, e As C1.Win.C1TrueDBGrid.FetchRowStyleEventArgs) Handles C1Screen1.FetchRowStyle
        Try
            Dim checkCols As String = yx
            If checkCols.Count > 0 Then
                Dim tempRow = C1Screen1.FocusedSplit.Rows.OfType(Of C1.Win.C1TrueDBGrid.BaseGrid.ViewRow).ToList()
                Dim flag As Boolean = False
                Dim origItem As String = ""
                For Each item As String In checkCols.Split(","c)
                    origItem = origItem + C1Screen1(e.Row, item.Trim("'"c)).ToString()
                Next
                For j As Integer = 0 To tempRow.Count - 1
                    Dim tempItem As String = ""
                        tempItem = tempItem + C1Screen1(j, item.Trim("'"c)).ToString()
                    Next
                    If Not flag AndAlso e.Row <> j Then
                        If origItem = tempItem Then
                            flag = True
                        End If
                    End If
                Next
                If flag Then
                    e.CellStyle.BackColor = Drawing.Color.DarkGreen
                    e.CellStyle.ForeColor = Drawing.Color.White
                End If
            Else
            End If
        Catch
            'ccc = 1
        End Try
    End Sub
    Victor
  • Posted 13 April 2020, 7:52 am EST
    Your case has been replied on the given link:
    https://www.grapecity.com/forums/winforms-edition/how-to-use-multtiselect-co#hi-victorthe-code-snippet-
    Please continue the thread there only.
