Help with including multiple C1TrueDBGrid in exported file (PDF & Excel)
Posted by: Victor.m.charles.civ on 13 January 2021, 9:43 pm EST
    Posted 13 January 2021, 9:43 pm EST
    How do I export C1Grid1 and Grid2 on the same excel sheet and How do I include both in a PDF with Landscape format?
    Victor
  • Posted 14 January 2021, 3:15 am EST
    Hello Victor,
    To export the TDB to pdf please go through the following blog post:
    https://www.grapecity.com/blogs/how-to-export-multiple-c1truedbgrids-to-one-pdf-excel-file
    If you want to set the orientation to landscape then use the following code:
    doc.PageLayout.PageSettings.Landscape = True
    doc.Export("CombinedPDF.pdf", True)
    To export multiple TDB in a single excel sheet please use the same approach just by replacing the following code:
    To:
    doc.Export("CombinedPDF.xlsx", True)
  • Posted 14 January 2021, 4:52 pm EST
    Thank you for your solution. I meant, If I have 3 grids on my Form, How do I export all three in a single excel worksheet.
    Victor
  • Posted 15 January 2021, 4:07 am EST
    Hello Victor,
    You can follow the same approach for 3 TrueDBGrids as did for the 2 TrueDBGrids in the blog sample.
    The code for exporting 3 TrueDBGrids is given below:
       Dim doc1 As New C1PrintDocument()
            doc1.Load("1.c1d", C1DocumentFormatEnum.C1d)
            Dim doc2 As New C1PrintDocument()
            doc2.Load("2.c1d", C1DocumentFormatEnum.C1d)
            Dim doc3 As New C1PrintDocument()
            doc3.Load("3.c1d", C1DocumentFormatEnum.C1d)
            ' the combined document:
            Dim doc As New C1PrintDocument()
            ' add 1st document:
            While doc1.Body.Children.Count > 0
                Dim ro As RenderObject = doc1.Body.Children(0)
                ' a render object cannot have two parents at once, so removed from original parent first:
                doc1.Body.Children.RemoveAt(0)
                ' now add to the combined doc:
                doc.Body.Children.Add(ro)
            End While
            ' ensure a page break between the two documents:
            doc.Body.Children.Add(New RenderEmpty(BreakEnum.Page))
            ' add 2nd document:
            While doc2.Body.Children.Count > 0
                Dim ro As RenderObject = doc2.Body.Children(0)
                doc2.Body.Children.RemoveAt(0)
            End While
            While doc3.Body.Children.Count > 0
                Dim ro As RenderObject = doc3.Body.Children(0)
                doc3.Body.Children.RemoveAt(0)
            End While
            doc.Export("Demo.xlsx", True)
             System.Diagnostics.Process.Start("Demo.xlsx")
  • Posted 18 January 2021, 10:53 pm EST
    How do I modify the code below to chose the folder I want to save the file instaed of saving to the TestFiles folder?
    Dim doc As New C1.C1Preview.C1PrintDocument()
    doc.Body.Children.Add(New C1.C1Preview.RenderText(vbLf & vbLf & “AOP-6”))
    doc.Body.Children.Add(New C1.C1Preview.RenderC1Printable(C1AOP5))
    doc.Body.Children.Add(New C1.C1Preview.RenderText(vbLf & vbLf & “AOP-8”))
    doc.Body.Children.Add(New C1.C1Preview.RenderC1Printable(C1AOP8))
    doc.Body.Children.Add(New C1.C1Preview.RenderText(vbLf & vbLf & “AOP-29”))
    doc.Body.Children.Add(New C1.C1Preview.RenderC1Printable(C1AOP29))
    doc.Body.Children.Add(New C1.C1Preview.RenderText(vbLf & vbLf & “AOP-40”))
    doc.Body.Children.Add(New C1.C1Preview.RenderC1Printable(C1AOP40))
    doc.Export(“C:\TestFiles\TEST66.pdf”, True)
    Victor
  • Posted 19 January 2021, 11:50 am EST
    Hello Prabhat,
    I noticed another issue when combining the Grids in one file or spreadsheet. How do you exclude a Grid if it’s invisible or record count is 0?
    Victor
  • Posted 20 January 2021, 12:00 am EST
    Hello Prabhat,
    Please disregard my last question.
    Thanks,.
    Victor
  • Posted 20 January 2021, 12:04 am EST
    Hello Prabhat,
    How do I modify the code below to include each AOP in a separate worksheet? For example I would to create an excel file with 4 separate worksheets.
    If ComboBox4.SelectedIndex = 1 Then
    Dim doc1 As New C1.C1Preview.C1PrintDocument()
    doc1.Body.Children.Add(New C1.C1Preview.RenderText(vbLf & vbLf & “AOP-6”))
    doc1.Body.Children.Add(New C1.C1Preview.RenderC1Printable(C1AOP5))
    doc1.Body.Children.Add(New C1.C1Preview.RenderText(vbLf & vbLf & “AOP-8”))
    doc1.Body.Children.Add(New C1.C1Preview.RenderC1Printable(C1AOP8))
    doc1.Body.Children.Add(New C1.C1Preview.RenderText(vbLf & vbLf & “AOP-20”))
    doc1.Body.Children.Add(New C1.C1Preview.RenderC1Printable(C1AOP29))
    doc1.Body.Children.Add(New C1.C1Preview.RenderText(vbLf & vbLf & “AOP-40”))
    doc1.Body.Children.Add(New C1.C1Preview.RenderC1Printable(C1AOP40))
    doc1.Export(“AMIS_Excel_Fle.xlsx”, True)
    System.Diagnostics.Process.Start(“AMIS_Excel_Fle.xlsx”)
    End If
    Victor
  • Posted 20 January 2021, 2:23 am EST
    Hello Victor,
    >>How do I modify the code below to choose the folder I want to save the file instead of saving to the TestFiles folder?
    You can use the code snippet given below:
    string dir = @"C:\YourFolderName";
    // If directory does not exist, create it
    if (!Directory.Exists(dir))
        Directory.CreateDirectory(dir);
    doc.Export("C:\YourFolderName\TEST66.pdf", True)
    You can go through the following blog post to learn how to export multiple C1TrueDbGrids to excel sheets:
    https://www.grapecity.com/blogs/how-to-export-multiple-c1truedbgrids-to-excel-sheets
  • Posted 21 January 2021, 12:31 pm EST
    Hello Prabhat,
    Is it possible to send me the solutions in VB.NET?
    Victor
  • Posted 22 January 2021, 1:40 am EST
    Hi Victor,
    You can download the same from here: https://www.dropbox.com/s/tluady2bjl5y3pa/ExportMultipleTDB_OneExcel_MultipleSheets_VB.zip?dl=0
    The sample works fine at our end.
