Posted 8 September 2017, 11:27 pm EST
How can I change the cell border color column divider
Posted by: scansoftpos on 8 September 2017, 11:27 pm EST
placed this code on load event
Dim i As Integer For i = 0 To GridCustomers.Columns.Count() - 1 "gridName".Splits(0).DisplayColumns(i).ColumnDivider.Style = C1.Win.C1TrueDBGrid.LineStyleEnum.None Next
Yes, you are right you would need to set the Style or Color property of the column divider to either hide the column divider or change its color respectively. Here is the code for the same:
[vb] //Change the color of the Column divider border c1TrueDBGrid1.Splits(0).DisplayColumns(0).ColumnDivider.Color = Color.Red //Hide the column divider border c1TrueDBGrid1.Splits(0).DisplayColumns(1).ColumnDivider.Style = C1.Win.C1TrueDBGrid.LineStyleEnum.None[/vb]
Hope it helps.
Manpreet Kaur
Posted 13 September 2017, 7:55 am EST
Can I change the Column Divider Color in the theme editor? Or only by code as shown?
Posted 15 September 2017, 7:10 am EST
Hello!
It won’t be possible to change column divider colour in the theme editor/designer. However, you can use the above suggested approach. in the scenario
In case of any other query, do let us know.
Meenakshi
Posted 26 April 2022, 7:29 am EST - Updated 3 October 2022, 10:29 pm EST
Hello.
I’ve seen this thread while I was looking for a way to change the column dividers with the Theme Editor. OK, this seems to be not possible and this is still the case in current versions. I can use the workaround mentioned above, even if this is not a good solution, because if have to handle the different themes by myself in that case.
But another and more important question is: How can I turn on the Column Dividers in die Column Headers? There are some Themes like MacSilver, where the Column Dividers in the grid itself are visible, but not in the Column Headers. This is important for our customers, because they have to grab and drag the Column Dividers to change the size of the columns. At the moment they have to grab an invisible thing:
Any help would be appreciated.
Kind regards,
Juergen
Posted 27 April 2022, 10:18 am EST
Hi Juergen,
In the C1TrueDBGrid, to show Cell borders in column headers while using the MacSilver theme, you can create your own custom theme by taking the MacSilver theme as the base theme in the C1ThemeDesigner application. In the designer app, you can change the value of the C1TrueDBGrid\Styles\Heading\Borders\BorderType property of your custom theme to show the borders. Kindly refer to the attached sample showing the same.
Posted 6 May 2022, 9:53 am EST - Updated 3 October 2022, 10:29 pm EST
Hi Kartik,
thanks for your reply and sorry for answering so late; I must have missed the notification, that there is an answer on this topic.
I’ve tried your example and this shows the borders in the column headers as expected. However, if I set this property in my custom themes, it does still not show the borders, at least in most of the grids. Strange.
You can possibly reproduce this behaviour on your side, because if I load your custom theme into the C1ThemeDesigner, it also does not show the column borders in the column captions:
Do you have an idea, which setting is responsible for this behaviour?
Thanks and kind regards,
Juergen
Posted 6 May 2022, 10:21 am EST - Updated 3 October 2022, 10:29 pm EST
Quality of the screenshot is bad, here is a detail:
Posted 9 May 2022, 7:03 am EST
Hi Juergen,
We could observe the issue while changing the BorderType property in the C1ThemeDesigner application. We have reported the issue to the development team and will let you know as soon as we have an update.
Although this issue is only observed in the Theme preview TrueDBGrid of the C1ThemeDesigner app. When the theme is saved and used in an application, it persists all the changes done from the C1ThemeDesigner app. Please try to use your custom themes in an application and see if the changes are being persisted or not.
[C1WIN-27340]
Kind Regards,
Posted 9 May 2022, 9:03 am EST
Hi Kartik,
thanks for reportig the issue to the development!
I’ve applied the saved theme to my application and the result is not always the same: some grids show the borders in the column headers and some don’t. I have no idea, which setting or property leads to the different behaviour.
Kind regards,
Juergen
Posted 10 May 2022, 12:25 am EST
Hi Juergen,
We could not replicate this behavior on our end. Please refer to the attached sample showing the behavior on our end. Could you please provide a small sample or update the attached sample to replicate the issue so we can investigate further and assist you in the best way possible? Also, please share the exact version of the C1 controls you are using.
Also, please let us know if you use any specific properties in the Grids (that do not persist the changes) that might be related to the heading style or if there are any specific steps that you follow to replicate the behavior, so we can investigate accordingly.
Kind Regards,
Posted 2 June 2023, 6:25 am EST
The issue reported in https://www.grapecity.com/forums/winforms-edition/hide-or-change-the-cell-border-colors#48768 has been fixed in the latest 2023v1(603) hotfix release. The hotfix release is available for installation from NuGet and ComponentOneControlPanel.
