How can I set the color of each point of the line on C1Chart
Posted by: a.koneva on 26 May 2022, 7:20 pm EST
  • Posted 26 May 2022, 7:20 pm EST
    Hi
    I am using C1Chart. I would like to set the color of each point of the line depending on some condition. Is there any solution for this?
    Anna.
  • Posted 27 May 2022, 1:05 am EST
    You can add the C1Chart PointStyles and handle the Select event for conditional coloring as:(see codes snippet)
    PointStyle ps =
    c1Chart1.ChartGroups[0].ChartData.PointStylesList.AddNewPointStyle();
    ps.Select += PointStyle_Select;
    ps.Selection = PointStyleSelectionEnum.Custom;
    private void PointStyle_Select(object sender, PointStyleSelectEventArgs e)
          /* value>40(Green Color) and value<=40(Red Color)*/
          double val = Convert.ToDouble(c1Chart1.ChartGroups[0].ChartData[e.SeriesIndex].Y[e.PointIndex]);
          C1.Win.C1Chart.PointStyle ps = (C1.Win.C1Chart.PointStyle)sender;
          ps.SymbolStyle.Color = val > 40 ? Color.Green : Color.Red;
          ps.SymbolStyle.Size = 10;
          e.Selected = true;
    Please refer the attached sample for the same : C1ChartPointColorDemo.zip
    Nitin.
  • Posted 6 June 2022, 6:07 pm EST
    Hi Nitin
    Thank you for your answer and a code sample.
    But I have another question. What if I have two ChartDataSeries on the chart and I want to cahnge colors of points (depending on some condition) on only one of the lines?
  • Posted 6 June 2022, 6:12 pm EST
    Oh, I see. I should use e.SeriesIndex.
  • Posted 6 June 2022, 11:03 pm EST
    You are correct, if you have multiple ChartDataSeries then you can update PointStyles for particular series by validating e.SeriesIndex.
    Nitin.
  • Posted 6 June 2022, 11:26 pm EST
    Hi Nitin
    Sorry but how can I get the index of the point that is being displayed in PointStyle_Select(object sender, PointStyleSelectEventArgs e)? It seems to me that e.PointIndex is equal to 0 for some time at first and then later it becomes to change 1, 2, 3, etc. Is it correct? Maybe I don’t understand how it works… (
    Anna
  • Posted 7 June 2022, 12:57 am EST
    Maybe this strange behavior appears because I redraw the list of points every second…
  • Posted 7 June 2022, 1:01 am EST
    Hello Anna,
    JFYI, PointStyle’s Select event fires for each point of every series in chart. You need to validate for series index for styling the points for a particular series. For example, If you have two series and wants different conditional coloring for both series. So, you need to validate according to the series index.(see code snippet)
                // value>40(Green Color) and value<40(Red Color) for series 1
                if (e.SeriesIndex==0)
                // value>10(Green Color) and value<10(Red Color) for series 2
                else if (e.SeriesIndex==1)
                    ps.SymbolStyle.Color = val > 10 ? Color.Green : Color.Red;
                e.Selected = true;
    Please refer the attached modified sample for the same: C1ChartPointColorDemo_Mod.zip
    Nitin
