How to add System.Drawing.Image to C1FlexReport.Field.Picture?
Posted by: l.balazs on 11 July 2025, 8:55 am EST
    Posted 11 July 2025, 8:55 am EST
    In .NET 8 the following statement causes run-time error in C1FlexReport8:
    private void PrintValue(C1.Win.FlexReport.Field field, System.Drawing.Image image)
    	field.Picture = image;
    Error = System.ArgumentException: ‘Invalid parameter for PictureHolder constructor.’
    Notes:
    1. The field .Picture has object type…
    2. This function just works fine up to .NET Framework 4.8.
    How can I fix this?
    Louis
  • Posted 14 July 2025, 4:33 am EST
    Hello Louis,
    The Picture property used to take a System.Drawing.Image object before but now it takes a GrapeCity.Documents.Drawing.Image object.
    Please refer to Picture property for more information: https://developer.mescius.com/componentone/docs/reporting/online-flexreport/C1.FlexReport~C1.Report.ImageField~Picture.html
    So you can update your code as follows:
        using (var ms = new MemoryStream())
            // Save the image as PNG to memory stream
            image.Save(ms, System.Drawing.Imaging.ImageFormat.Png);
            // Convert to GcImage and assign to the field
            field.Picture = GrapeCity.Documents.Drawing.Image.FromBytes(ms.ToArray());
    Uttkarsh.
