How to change Double click on a unselected row behaviour in True DB Grid
Posted by: asif.arshadullah on 22 February 2021, 4:55 am EST
    Posted 22 February 2021, 4:55 am EST
    Current behaviour of True DB Grid for Winforms is that if a user double clicks on a unselected row, the row becomes editable. I want to change this to the following behaviour:
    If a user double clicks on a unselected row, then the row is only selected not editable. But if a user clicks on a selected row, the row becomes editable.
  • Posted 23 February 2021, 2:29 am EST
    The single-click always fires before double click so you will need to use a timer with the combination of MouseClick and MouseDoubleClick events and wait when the click occurs to see if it was a double click. Once you know if the click was single or double you can perform the required operations. You can use the EditActive property to begin editing if a single click occurred. You can use the Select method to select the row when a double click occurred.
    Please refer to the sample attached. If you need further assistance, please let us know.
    Regards.
    Avnish
    TDBGridClickChange.zip
