How to change Highlight Style in C1flexgrid | WinForm
Posted by: agopwns on 20 April 2018, 2:45 am EST
    Posted 20 April 2018, 2:45 am EST
    C1flexgrid | WinForm | C#
    I want to change the highlight Style.
    I use this code.
    this.Styles.Highlight.BackColor = Color.Red;
    this.Styles.Focus.BackColor = this.Styles.Highlight.BackColor;
    But it’s only ‘Focus.BackColor’ work.
    Doesn’t work ‘Highlight.BackColor’.
    What’s wrong this code?
  • Posted 20 April 2018, 7:16 am EST
    Hi agopwns,
    works for me, see attached sample ;-). Note that the highlight color will only be visible if you select multiple cells.
    FlexHighlight.zip
    Did you set a VisualStyle to the flexgrid, or do you use C1Themes? Both might overwrite the highlight style.
  • Posted 22 April 2018, 6:57 pm EST
    Oh, I used VisualStyle.
    Thank you for your answer : )
  • Posted 23 April 2018, 3:04 am EST
    in this situation, you might change the “Highlight” style after setting the VisualStyle. Probably, you will have to do this in code, e.g. in the “OnLoad” override.
