How to insert a string value into a column that is the type of column is int
Posted by: samo3889 on 12 November 2017, 6:06 am EST
    Posted 12 November 2017, 6:06 am EST
    I have a column that the Datatype of column is int .
    i have function that convert each int to string and insert into the column But not updated because his type is different than column , Then returns the value as it was.
    i want to be DisplayMember is string
    and ValueMember is int
    How can I do something like that (DataMap or Translate)?
    i use Combolist (…) for int Values, in separate window we select the values,
    (look at the following example in Attachment.)
    Saleem j
    TestCodeC1flexGrid.zip
  • Posted 13 November 2017, 6:15 am EST
    take a look at the C1FlexGrid sample “DataMap”: https://www.grapecity.com/en/samples/datamap
    Hope this helps
  • Posted 14 November 2017, 1:26 am EST
    Hi!
    Thanks Wolfgang.
    And Saleem! yes, you can use DataMap property of FlexGridClassic column to achieve the desired behaviour. I am attaching the modified sample for your reference.
    To know more about DataMap, you can see this:
    http://helpcentral.componentone.com/nethelp/c1flexgrid/C1.Win.C1FlexGrid.4~C1.Win.C1FlexGrid.RowCol~DataMap.html
    Meenakshi
    Prj_GridDataMap.zip
  • Posted 15 November 2017, 12:26 pm EST
    Hi!
    Thanks Wolfgang , Meenakshi
    Meenakshi i have looked up on your attachment “Prj_GridDataMap.zip”
    i notice that you convert the column to comboBox but i want to keep as is
    “choose an option by select item by another form”
    how i can do it without convert column to comboBox ?
    Saleem
  • Posted 16 November 2017, 4:50 am EST
    Hi Saleem,
    I modified your sample so that the column contains an ID value, but the ID is replaced with a text. Note that your selection form also has to provide the selected ID instead of the selected text.
    Hope this helps
  • Posted 16 November 2017, 6:10 am EST
    Thanks Wolfgang :slight_smile:
    • Meenakshi
  • Posted 16 November 2017, 10:15 am EST
    Thank you Wolfgang for your help and support i really appreciate :slight_smile:
    Saleem
