How to insert C1DashboardLayout in VB Programmatically?
Posted by: nitin on 16 May 2020, 12:36 am EST
    Posted 16 May 2020, 12:36 am EST
    I want to create the Dashboard dynamically, without inserting it at design time.
    Please give some sample code.
  • Posted 18 May 2020, 8:06 am EST
    Hi Nitin,
    I have attached a demo sample which shows how you can create a DashBoardLayout control via code, please have a look.
    DashBoardDemo.zip
  • Posted 20 May 2020, 9:17 am EST
    Sir,
    Its giving error because there is no Table with name Data in my C1NWind.mdb.
    Where can I find the latest C1NWind.mdb?
  • Posted 20 May 2020, 11:47 pm EST
    Hi Nitin,
    It is very strange that your C1NWind.mdb file does not have the table with the name Data. To get the correct C1NWind DB and samples, you can repair your installed product by Checking the Install Samples option when using ComponentOneControlPanel utility that you can download from here:
    I have also attached the C1NWind.mdb file below, you can also download it from here and replace it with your existing one.
    C1NWind.zip
  • Posted 28 May 2020, 1:16 pm EST
    Thanks, Working properly.
