How to Prevent Attached Event When I Click Qat.MenuItem
Posted by: dnjsxmf on 26 October 2020, 4:31 am EST
    Posted 26 October 2020, 4:31 am EST - Updated 3 October 2022, 11:34 pm EST
    Hello
    I am using C1.Win.C1Ribbon.2.dll (Version = 2.0.20113.351)
    I want to make a button like “Show Below the Ribbon” button in Qat (Quick Access Toolbar) dropdown Menu
    When I Add Ribbon button (I also add Click event in that) to Qat.MenuItem, It added to Qat dropdown Menu ( shown dropdown menu name is “Customize Quick Access Toolbar”).
    if I click the Ribbon button, its click event is not called and it just Attached to left side of dropdown menu.
    How to Prevent Attaching and checkMark when I click that button in Qat dropdown menu.
    my expected work :
    1. I click my Qat menu Item (“ShowMsg”).
    2. Its click event called (not attached left side, not show checkMark)
            private void Form1_Load(object sender, EventArgs e)
                RibbonButton button = new RibbonButton() { Text = "ShowMsg"};
                button.Click += Button_Click;
                ribbonQat1.MenuItems.Add(button);
            private void Button_Click(object sender, EventArgs e)
                MessageBox.Show("Message");
    Thanks in advanced,
    1min
  • Posted 26 October 2020, 5:48 am EST
    as far as I know, you can only attach buttons to the QAT that are contained in the ribbon. So, you would have to add the button to a RibbonGroup (or the ApplicatiopnMenu or the RibbonConfigToolbar) before adding it to the QAT.
  • Posted 28 October 2020, 3:07 am EST
    You can’t do what you mentioned in the “Customize Quick Access Toolbar” dropdown but as a workaround, you can add a split button to the Qat and then add items in its dropdown which will work as you mentioned. Please refer to the sample attached.
    @Wolfgang, thank you for your suggestion.
    C1RibbonQat.zip
