How to set DataType of XLColumn/Cell
Posted by: michael.chojetzki on 11 November 2019, 11:05 am EST
  • Posted 11 November 2019, 11:05 am EST
    Is there a way to set the DataType of a Cell or a Column? I don’t mean the String Format as in “sheet.Columns(x).Style.Format”. I think of something like “sheet.Columns(x).DataType”.
  • Posted 13 November 2019, 3:08 am EST
    C1Excel is designed to provide the same functionality as Microsoft Excel.
    As columns in MS Excel does not have any DataType property (it has Format Cells option) so DataType property is not available for C1Excel’s Columns.
    You can check out our Spread control which is also similar to MS Excel and provide you the functionality to set the datatype of the column as given in the link below :
    https://www.grapecity.com/spreadnet/docs/v13/online-win/FarPoint.Win.Spread~FarPoint.Win.Spread.Data.SpreadDataColumn~DataType.html
  • Posted 13 November 2019, 4:09 am EST - Updated 4 October 2022, 12:32 am EST
    which format do I have to add to the cell so that the hint from Excel disappears:
    The Hint says: “Number stored as text”
  • Posted 14 November 2019, 12:54 am EST
  • Posted 14 November 2019, 3:07 am EST
    You can use the Spread for Winform to achieve your requirements. In Spread, You can assign the CellType(Like Number) to the cell, which is saved as Number type cell in exported excel file. Please refer to the following documentation and the attached sample.
    https://www.grapecity.com/spreadnet/docs/v13/online-win/spwin-setcelltypes.html
    Hope it helps.
