Posted 29 August 2018, 6:50 pm EST
I have an application with 2 flex charts, each share the same horizontal axis data but have different vertical axis data sets.
I want to have a line marker which tracks with the mouse, one on chart, and a line marker on the other has its position updated to keep in sync with the first linemarker
Using an earlier version of the flexchart component, I was able to raise and event when the mouse moved on one chart that effectively updated the linemarker position in the other chart. (I was setting the X and Y values of the linemarker)
with the latest version of the component, I set the horizontal and vertical values of the second line marker (and they seem to update), but the actual position of the linemarker doesn’t change.
I already invalidate the flexchart after updating the linemarker position.
any ideas?
thanks
Richard
