Is it possible to enable/disable the series in the Chart
Posted by: amit.jain3 on 27 April 2023, 5:58 am EST
  • Posted 27 April 2023, 5:58 am EST
    If I have 15-20 series plotted into the same chart and I want to view a specific series is it possible to hide other series and enable the specific one?
    1 more thing I would like to ask. As of now I am using C1Charts which have 2 axis X/Y. If I want to introduce new Axis “Z” can it be done in the normal charts or for that we need to use 3D one?
  • Posted 30 April 2023, 7:09 am EST
    Hi Amit,
    You can set the Display property of C1Chart’s SeriesList items to Hidden for the series which you want to hide. Please refer to the following code:
    c1Chart1.ChartGroups[0].ChartData.SeriesList[1].Display = C1.Win.C1Chart.SeriesDisplayEnum.Hide;
    Kindly refer to the attached sample for full implementation. (Download C1ChartHideSeries.zip using the link: *https://www.dropbox.com/s/0ir1yug2v9t66h7/C1ChartHideSeries.zip?dl=0)
    You can achieve the requirement by using C1Chart3D control. Please refer to the following documentation link for the same: *https://www.grapecity.com/componentone/docs/win/online-chart3d/overview.html
    Hope this helps. Please let us know if you have any further concerns.
    Thanks & Regards,
    Aastha
  • Posted 3 May 2023, 6:34 am EST
    Thank you Aastha for the information. I’ll look into the solution and get back to you if I have doubts.
  • Posted 3 May 2023, 8:03 am EST
    Hello Aastha, Is it possible to add the ZIP for Hide Series Directly Here.
    dropbox links are not accessible for me
  • Posted 4 May 2023, 1:02 am EST
    Hi Amit,
    Please find the sample attached. (Refer C1ChartHideSeries.zip)
    Kindly let us know if you have any further issues.
    Thanks & Regards,
    Aastha
  • Posted 4 May 2023, 3:36 am EST
    Hi Aastha,
    Sorry for the inconvenience, Can you share an example without using Database connections. I cannot run the solution.
  • Posted 4 May 2023, 6:10 am EST - Updated 4 May 2023, 6:15 am EST
    Hi Aastha,
    I have 1 more question In the Image I have marked a value and I believe that is called Legend.
    If yes I am using below Line to show the legend -
    c1Chart1.Legend.TooltipText = “Hello”;
    c1Chart1.Legend.Orientation = LegendOrientationEnum.Auto;
    c1Chart1.Legend.Text = “Chart”;
    But it is not working. can you correct me what wrong I am doing
  • Posted 4 May 2023, 11:01 am EST
    Hi Aastha,
    I am able to get the Legends. Is it possible to populate all the Legends into a dropdown?
  • Posted 5 May 2023, 1:43 pm EST
    Hi Amit,
    You can populate all the legends in a combobox by accessing each element of C1Chart.ChartGroups[0].ChartData’s SeriesList property. You can refer to the following code snippet for the same:
    var seriesCollection = c1Chart1.ChartGroups[0].ChartData.SeriesList;
    comboBox1.Items.Clear();
    if (seriesCollection != null)
        for(int i=0; i<seriesCollection.Count; i++)
            comboBox1.Items.Add(seriesCollection[i]);
    Taking into account the above requirement, we have created an updated version of the sample application where user can display a particular series selected in a combobox. Please refer C1ChartHideSeriesObj.zip
    Hope this helps. Please let us know if you have any further issues.
    Thanks & Regards,
    Aastha
