Is there a way to copy a C1FlexGrid to another C1FlexGrid
Posted by: mhamilton on 26 May 2022, 8:00 pm EST
    Posted 26 May 2022, 8:00 pm EST
    Is there a way to copy a C1FlexGrid to another C1FlexGrid. I need all styles and data to be copied. Looking for a simple way to do this without looping through the styles, rows and columns.
    Thanks!
  • Posted 27 May 2022, 7:03 am EST
    Unfortunately, there is no direct way of copying a C1FlexGrid into another. You will need to write a method according to your own requirements.
    Although, you can use some Grid methods such as WriteXml to copy the Data directly into another Grid using a temporary XML file and then copying the Styles manually. You can also use the SaveExcel method to export a temporary Excel file in a memory stream which will copy the styles also and then load it into another Grid. Kindly refer to the attached sample showing the above approaches.
    CopyGrid_FG.zip
  • Posted 27 May 2022, 9:59 am EST
    Thank you! I appreciate all the help and support!
