Issues with Series in FlexChart
Posted by: andrea.davoli on 11 June 2025, 11:22 am EST
  • Posted 11 June 2025, 11:22 am EST - Updated 11 June 2025, 11:29 am EST
    I’m encountering a couple of issues while migrating from C1Chart to FlexChart, as I’m updating my project to .NET 8 using WinForms.
    I have a chart that originally used a bar series and a line series (with points), like this:
    With FlexChart, I’m struggling with two main things:
    Coloring a specific bar:
    In C1Chart, I used PointStylesList to change the color of a single bar. I can’t find a way to do this in FlexChart.
    Using both bars and lines in the same chart:
    If I add only the bar series, the chart renders fine. If I add only the line series, it also works.
    But when I try to add both, it renders incorrectly — the whole chart takes on the chart type of whichever series is added first (all bars or all lines).
    Below is the working code I used with C1Chart:
    [code] Private Sub CaricaGraficoProiezioni()
    Me.Size = New Size(1300, 620)
    Me.Location = New System.Drawing.Point(160, 165)
        Dim i, d As Integer
        Dim sty2 As Style = C1ChartProiezioni.Style
        sty2.BackColor = Color.WhiteSmoke
        sty2.BackColor2 = Color.WhiteSmoke
        Dim bord2 As Border = sty2.Border
        bord2.Rounding.All = 10
        bord2.Thickness = 1
        sty2 = C1ChartProiezioni.Legend.Style
        C1ChartProiezioni.ChartArea.AxisY.Text = etichetta & If(um <> "", " (" & um & ")", "")
        C1ChartProiezioni.ChartArea.AxisX.Text = trad.TradMsg("Giorni di lattazione")
        Dim NRec As Integer = arrayserie.Length - 2
        Dim xDIM() As Double
        Dim xdata() As Double
        Dim xdata0() As Double
        Dim xlabels() As String
        Dim ydata1() As Double
        Dim ydata2() As Double
        Dim ydata3() As Double
        Dim PolinomialCurve As Boolean = True
        ReDim xDIM(NRec - 1)
        ReDim xdata(NRec - 1) : ReDim xdata0(NRec - 2)
        ReDim xlabels(NRec - 1)
        ReDim ydata1(NRec - 1)
        ReDim ydata2(NRec - 1)
        ReDim ydata3(NRec - 1)
        For i = 0 To NRec - 1
            xdata(i) = i
            If i < NRec - 1 Then xdata0(i) = i
            xDIM(i) = Scheda.Dati(SchedaSelezionata).Raz.projDIM(i + 1)
            xlabels(i) = Scheda.Dati(SchedaSelezionata).Raz.projDIM(i + 1)
            ydata1(i) = arrayserie(i + 1)
            If idxitem = 7 Then
                ydata2(i) = Math.Round(arrayserie1(i + 1), 1)
            ElseIf idxitem = 8 Then
                ydata3(i) = Math.Round(arrayserie2(i + 1), 1)
            End If
        Next
        Dim ValMaxY0 As Single
            If ydata1(i) > ValMaxY0 And Not IsInfinityDbl(ydata1(i)) Then
                ValMaxY0 = ydata1(i)
            End If
        Next
        Dim ValMinY As Single = ydata1(0)
        For i = 1 To NRec - 1
            If ydata1(i) < ValMinY Then
                ValMinY = ydata1(i)
            End If
        Next
        If ValMinY < 0 Then
            C1ChartProiezioni.ChartArea.AxisY.Min = Math.Round(ValMinY * 1.5, 1)
        Else
            C1ChartProiezioni.ChartArea.AxisY.Min = Math.Floor(ValMinY / 1.3)
        End If
        C1ChartProiezioni.ChartArea.AxisY2.Min = C1ChartProiezioni.ChartArea.AxisY.Min
        Dim ValMaxY As Single = ValMaxY0
        If idxitem = 7 Or idxitem = 8 Then
            Dim ValMaxY1 As Single
                If ydata2(i) > ValMaxY1 And Not IsInfinityDbl(ydata2(i)) Then
                    ValMaxY1 = ydata2(i)
                End If
            Next
            Dim ValMinY1 As Single = ydata2(0)
                If ydata2(i) < ValMinY1 Then
                    ValMinY1 = ydata2(i)
                End If
            Next
            Dim ValMaxY2 As Single
                If ydata3(i) > ValMaxY2 And Not IsInfinityDbl(ydata3(i)) Then
                    ValMaxY2 = ydata3(i)
                End If
            Next
            Dim ValMinY2 As Single = ydata3(0)
                If ydata3(i) < ValMinY2 Then
                    ValMinY2 = ydata3(i)
                End If
            Next
            If Math.Max(ValMaxY1, ValMaxY2) > ValMaxY0 Then
                ValMaxY = Math.Max(ValMaxY1, ValMaxY2)
            End If
        End If
        C1ChartProiezioni.ChartArea.AxisX.UnitMajor = 30
        C1ChartProiezioni.ChartArea.AxisY.UnitMajor = CInt(ValMaxY - (ValMinY / 2)) / 10
        C1ChartProiezioni.ChartArea.AxisY.UnitMinor = CInt(ValMaxY - (ValMinY / 2)) / 20
        C1ChartProiezioni.ChartArea.AxisY.Max = ValMaxY * 1.04
        C1ChartProiezioni.ChartArea.AxisY.AnnoFormat = FormatEnum.NumericManual
        C1ChartProiezioni.ChartArea.AxisY.AnnoFormatString = "#,##0.0;-#,##0.0"
        With C1ChartProiezioni.ChartGroups(1).ChartData.SeriesList
            .Clear()
            Dim ds1 As C1.Win.C1Chart.ChartDataSeries
            ds1 = .AddNewSeries()
            ds1.Label = etichetta
            ds1.X.CopyDataIn(xdata0)
            ds1.Y.CopyDataIn(ydata1)
            ds1.FillStyle.Color1 = Color.LightSteelBlue
            ds1.FillStyle.OutlineColor = Color.Black
            If idxitem = 7 Then
                Dim ds2 As C1.Win.C1Chart.ChartDataSeries
                ds2 = .AddNewSeries()
                ds2.Label = etichetta2
                ds2.X.CopyDataIn(xdata0)
                ds2.Y.CopyDataIn(ydata2)
                ds2.FillStyle.Color1 = Color.CadetBlue
                ds2.FillStyle.OutlineColor = Color.Black
                Dim ds3 As C1.Win.C1Chart.ChartDataSeries
                ds3 = .AddNewSeries()
                ds3.Label = etichetta2
                ds3.X.CopyDataIn(xdata0)
                ds3.Y.CopyDataIn(ydata3)
                ds3.FillStyle.Color1 = Color.AliceBlue
                ds3.FillStyle.OutlineColor = Color.Black
            End If
        End With
            .ChartType = Chart2DTypeEnum.Bar
            .Stacked = False
        End With
        C1ChartProiezioni.ChartGroups(1).Bar.ClusterWidth = 80 'larghezza barra
        C1ChartProiezioni.ChartLabels.LabelsCollection.Clear() 'pulisco le etichette
        C1ChartProiezioni.ChartGroups(1).ChartData.PointStylesList.Clear()
        C1ChartProiezioni.ChartArea.AxisY.Origin = 0
        C1ChartProiezioni.ChartArea.AxisY2.Max = C1ChartProiezioni.ChartArea.AxisY.Max
        C1ChartProiezioni.ChartArea.AxisY2.Visible = False
        C1ChartProiezioni.ChartArea.AxisX.Font = New Font("Tahoma", 8, FontStyle.Regular)
        C1ChartProiezioni.ChartArea.AxisY.Font = New Font("Tahoma", 8, FontStyle.Bold)
        C1ChartProiezioni.Legend.Visible = True
        C1ChartProiezioni.Legend.Style.Font = New Font("Tahoma", 9, FontStyle.Bold)
        C1ChartProiezioni.Legend.Compass = CompassEnum.South
        With C1ChartProiezioni.ChartArea.AxisX
            .ValueLabels.Clear()
            For i = 0 To NRec - 2
                .ValueLabels.Add(i, xlabels(i))
            Next
            .AnnoMethod = C1.Win.C1Chart.AnnotationMethodEnum.ValueLabels
            .TickMinor = C1.Win.C1Chart.TickMarksEnum.None
        End With
        'colorazione barre
        Dim pstyles As PointStylesCollection = C1ChartProiezioni.ChartGroups(1).ChartData.PointStylesList
        pstyles.Clear()
        Dim ps0 As PointStyle = pstyles.AddNewPointStyle
        ps0.PointIndex = indxgreen - 1
        ps0.FillStyle.Color1 = Color.LightGreen
            Dim ps1 As PointStyle = pstyles.AddNewPointStyle
            ps1.PointIndex = indxgreen - 1
            ps1.SeriesIndex = 1
            ps1.FillStyle.Color1 = Color.Green
            Dim ps2 As PointStyle = pstyles.AddNewPointStyle
            ps2.PointIndex = indxgreen - 1
            ps2.SeriesIndex = 2
            ps2.FillStyle.Color1 = Color.Honeydew
        End If
        'etichette dei valori
            Dim lblX0 As C1.Win.C1Chart.Label = C1ChartProiezioni.ChartLabels.LabelsCollection.AddNewLabel()
            With lblX0
                .AttachMethod = AttachMethodEnum.DataIndexY
                .AttachMethodData.GroupIndex = 1
                .AttachMethodData.SeriesIndex = 0
                .AttachMethodData.PointIndex = i
                .AttachMethodData.Y = ydata1(i)
                .Style.Font = New Font("Arial", 7.5, FontStyle.Regular)
                Select Case idxitem
                    Case = 1, 2, 7, 8
                        'DMI, Latte attuale, ME Milk, MP Milk
                        .Text = Format(ydata1(i), "#,##0.0;-#,##0.0; ")
                        PolinomialCurve = False
                    Case = 11
                        'Peso Vivo
                        .Text = Format(ydata1(i), "#,##0;-#,##0; ")
                    Case Else
                        .Text = Format(ydata1(i), "#,##0.00;-#,##0.00; ")
                End Select
                If ydata1(i) >= 0 Then
                    .Compass = LabelCompassEnum.North
                Else
                    .Compass = LabelCompassEnum.South
                End If
                .Offset = 15
                .Connected = If(Math.Round(ydata1(i), 2) <> 0, True, False)
                .Style.BackColor = Color.Transparent
                .Style.ForeColor = Color.Black
                .Visible = True
            End With
        Next
        Dim HeaderText As String = trad.TradMsg("Risultati attesi") & ": "
        C1ChartProiezioni.Header.Text = HeaderText & etichetta
        If idxitem = 7 Then
            C1ChartProiezioni.Header.Text = HeaderText & trad.TradMsg("Latte permesso da ME")
            C1ChartProiezioni.Header.Text = HeaderText & trad.TradMsg("Latte permesso da MP")
        End If
        C1ChartProiezioni.Header.Visible = True
        C1ChartProiezioni.Header.Style.Font = New Font("Tahoma", 11, FontStyle.Bold)
        C1ChartProiezioni.Header.Style.BackColor = Color.WhiteSmoke
        C1ChartProiezioni.Visible = True
        'Serie fittizia ChartGroups(0) per far vedere l'asse della Y
        C1ChartProiezioni.ChartGroups(0).ChartData.SeriesList.Clear()
        Dim ds44 As C1.Win.C1Chart.ChartDataSeries = C1ChartProiezioni.ChartGroups(0).ChartData.SeriesList.AddNewSeries()
        ds44.LegendEntry = False
        If PolinomialCurve Then
            Dim Stat As New Statistiche
            Dim Grado As Integer = 6
            Stat.LS_PolynomialFitting(Grado, NRec, xDIM, ydata1)     'la condizione affinchè ci siano i risultati è Stat.Solution_Problem = False
            Dim R2 As Double = Stat.Get_R2  'restituisce il valore di R2
            'i coefficienti sono memorizzati nell'array Stat.RegrPolyCoeff.
            Dim strCoeff As String = ""
            For i = 0 To Grado
                strCoeff = strCoeff & Stat.RegrPolyCoeff(i) & " * x^" & i & vbCrLf
            Next
            strCoeff = "y = " & strCoeff
            'calcolo di valori aggiuntivi attraverso il polinomio
            Dim n As Integer = -1
            Dim pDIM() As Double
            For i = xDIM(0) To xDIM(NRec - 1)
                n += 1
                ReDim Preserve pDIM(n)
                pDIM(n) = i
            Next
            Dim k(n) As Double
            k = Stat.Calc_y_Vals(pDIM) 'calcolo dei valori corrispondenti alle x
            Dim ydata4() As Double = k
            If idxitem = 10 Then
                Dim BCScalv As Double = Stat.GetZeroDegreeCoeff
                'Condizione per avere BCS mx=5
                d = 0
                Do
                    d += 1 : If d = ydata4.Length - 1 Then Exit Do
                Loop Until ydata4(d) = 5
                If d < ydata4.Length - 1 Then
                    For i = d To ydata4.Length - 1
                        ydata4(i) = 5
                    Next
                End If
            End If
            Dim xdata4(ydata4.Length - 1) As Double
            xdata4(0) = 0
            For i = 1 To ydata4.Length - 1
                xdata4(i) = xdata4(i - 1) + (xdata.Length - 1) / xdata4.Length
            Next
            ReDim Preserve xdata4(ydata4.Length - xDIM(0) - 5)
            Dim ds4 As C1.Win.C1Chart.ChartDataSeries
            ds4 = C1ChartProiezioni.ChartGroups(0).ChartData.SeriesList.AddNewSeries()
            ds4.X.CopyDataIn(xdata4)
            ds4.Y.CopyDataIn(ydata4)
            ds4.LineStyle.Color = Color.Red
            ds4.LineStyle.Thickness = 2
            ds4.SymbolStyle.Shape = SymbolShapeEnum.Dot
            ds4.SymbolStyle.Size = 3
            ds4.SymbolStyle.Color = Color.Red
            ds4.Label = trad.TradMsg("Andamento atteso")
            C1ChartProiezioni.ChartGroups(0).ChartType = Chart2DTypeEnum.XYPlot
        End If
        ' Enable tooltip
        DataSeriesTooltipText1 = "{#YVAL}"
        C1ChartProiezioni.ToolTip.PlotElement = PlotElementEnum.Points
        C1ChartProiezioni.ToolTip.Enabled = True
    End Sub[/code]
    And here is the current FlexChart version with the issues described above:
    [code]Private Sub CaricaFlexChartProiezioni()
    Me.Size = New Size(1400, 620)
    Dim i, d As Integer
        FlexChartProiezioni.Series.Clear()
        FlexChartProiezioni.BackColor = Color.WhiteSmoke
        FlexChartProiezioni.AxisY.Title = etichetta & If(um <> "", " (" & um & ")", "")
        FlexChartProiezioni.AxisX.Title = trad.TradMsg("Giorni di lattazione")
            xdata(i) = i
            If idxitem = 7 Then
            End If
        Next
            End If
        Next
                ValMinY = ydata1(i)
            End If
        Next
        If ValMinY < 0 Then
            FlexChartProiezioni.AxisY.Min = Math.Round(ValMinY * 1.5, 1)
        Else
            FlexChartProiezioni.AxisY.Min = Math.Floor(ValMinY / 1.3)
        End If
                End If
            Next
                End If
            Next
                End If
            Next
                End If
            Next
            End If
        End If
        FlexChartProiezioni.AxisY.Max = ValMaxY * 1.04
        ' create a datatable
        Dim dt As New DataTable("Curva1")
        ' add columns to the datatable
        dt.Columns.Add("xlabels", GetType(String))
        dt.Columns.Add(etichetta, GetType(Double))
        If idxitem = 7 OrElse idxitem = 8 Then dt.Columns.Add(etichetta2, GetType(Double))
        ' add rows to the datatable
        If idxitem = 7 Then
            For i = 0 To xdata.Length - 1
                dt.Rows.Add(xlabels(i), ydata1(i), ydata2(i))
            Next
                dt.Rows.Add(xlabels(i), ydata1(i), ydata3(i))
            Next
        Else
                dt.Rows.Add(xlabels(i), ydata1(i))
            Next
        End If
        ' specify the datasource for the chart
        FlexChartProiezioni.DataSource = dt
        ' bind the X-axis
        FlexChartProiezioni.BindingX = "xlabels"
        Dim ds1 As New C1.Win.Chart.Series
        Dim ds2 As C1.Win.Chart.Series
        Dim ds3 As C1.Win.Chart.Series
        FlexChartProiezioni.Series.Add(ds1)
        If idxitem = 7 Then
            ds2 = New C1.Win.Chart.Series
            FlexChartProiezioni.Series.Add(ds2)
        End If
        If idxitem = 8 Then
            ds3 = New C1.Win.Chart.Series
            FlexChartProiezioni.Series.Add(ds3)
        End If
        ds1.Binding = etichetta
        ds1.Name = etichetta
        ds1.ChartType = C1.Chart.ChartType.Column
        ds1.Style.FillColor = Color.LightSteelBlue
        ds1.Style.StrokeColor = Color.Black
        ds1.DataLabel = New C1.Win.Chart.DataLabel()
        With ds1.DataLabel
            Try
                Select Case idxitem
                    Case = 1, 2, 7, 8
                        .Content = "{y:F1}" ', "#,##0.0;-#,##0.0; " 'Mostra il valore della Y
                    Case = 11
                        'Peso Vivo
                        .Content = "{y:F1}"
                    Case Else
                        .Content = "{y:F1}"
                End Select
            Catch ex As Exception
            End Try
            .Position = C1.Chart.LabelPosition.Top   ' Posizione sopra la barra
            .Border = False
            .ConnectingLine = True
            .Offset = 15
            .Style.FillColor = Color.Black
        End With
        If idxitem = 7 Then
            ds2.Binding = etichetta2
            ds2.Name = etichetta
            ds2.ChartType = C1.Chart.ChartType.Column
            ds2.Style.FillColor = Color.CadetBlue
            ds2.Style.StrokeColor = Color.Black
            ds3.Binding = etichetta2
            ds3.Name = etichetta
            ds3.ChartType = C1.Chart.ChartType.Column
            ds3.Style.FillColor = Color.AliceBlue
            ds3.Style.StrokeColor = Color.Black
        End If
        FlexChartProiezioni.Options.ClusterSize.Value = 80 'larghezza barra
        FlexChartProiezioni.AxisX.Style.Font = New Font("Tahoma", 8, FontStyle.Regular)
        FlexChartProiezioni.AxisY.Style.Font = New Font("Tahoma", 8, FontStyle.Bold)
        FlexChartProiezioni.Legend.Style.Font = New Font("Tahoma", 9, FontStyle.Bold)
        FlexChartProiezioni.Legend.Position = C1.Chart.Position.Bottom
        'colorazione barre
        'Dim s As New C1.Win.Chart.Series()
        's.Name = "Serie1"
        's.Binding = "yval"
        'FlexChartProiezioni.Series.Add(s)
        'Dim pstyles As PointStylesCollection = FlexChartProiezioni.ChartType.
        'pstyles.Clear()
        'Dim ps0 As PointStyle = pstyles.AddNewPointStyle
        'ps0.PointIndex = indxgreen - 1
        'ps0.FillStyle.Color1 = Color.LightGreen
        'If idxitem = 7 Or idxitem = 8 Then
        '    Dim ps1 As PointStyle = pstyles.AddNewPointStyle
        '    ps1.PointIndex = indxgreen - 1
        '    ps1.SeriesIndex = 1
        '    ps1.FillStyle.Color1 = Color.Green
        '    Dim ps2 As PointStyle = pstyles.AddNewPointStyle
        '    ps2.PointIndex = indxgreen - 1
        '    ps2.SeriesIndex = 2
        '    ps2.FillStyle.Color1 = Color.Honeydew
        'End If
        FlexChartProiezioni.Header.Content = HeaderText & etichetta
        If idxitem = 7 Then
            FlexChartProiezioni.Header.Content = HeaderText & trad.TradMsg("Latte permesso da ME")
            FlexChartProiezioni.Header.Content = HeaderText & trad.TradMsg("Latte permesso da MP")
        End If
        FlexChartProiezioni.Header.Style.Font = New Font("Tahoma", 11, FontStyle.Bold)
        FlexChartProiezioni.Header.Style.StrokeColor = Color.WhiteSmoke
        FlexChartProiezioni.Visible = True
            For i = 0 To Grado
            Next
                n += 1
                pDIM(n) = i
            Next
            Dim k(n) As Double
                d = 0
                Do
                        ydata4(i) = 5
                    Next
                End If
            End If
            xdata4(0) = 0
            Next
            Dim ds4 As New C1.Win.Chart.Series
            ds4.ChartType = C1.Chart.ChartType.SplineSymbols
            For i = 0 To xdata4.Length - 1
                dt.Rows.Add(xdata4(i), ydata4(i))
            Next
            FlexChartProiezioni.Series.Add(ds4)
            ds4.Style.FillColor = Color.Red
            ds4.Style.StrokeWidth = 2
            ds4.Style.LinePattern = SymbolShapeEnum.Dot
            ds4.SymbolSize = 3
            ds4.SymbolStyle.FillColor = Color.Red
            ds4.Name = trad.TradMsg("Andamento atteso")
        End If
        ' Enable tooltip
        FlexChartProiezioni.ToolTip.Active = False
        FlexChartProiezioni.Dock = DockStyle.Fill
    End Sub[/code]
    Any suggestions or examples would be greatly appreciated.
    Thanks!
  • Posted 12 June 2025, 4:27 am EST
    Thank you for sharing the screenshot and sample code.
    To change the color of an individual bar, you can handle the SymbolRendering event of the series and set the Fill color for the specific bar using the IRenderEngine.
    Additionally, you can add multiple series to the FlexChart.Series collection and set the ChartType property of each series to Column or Line, as needed.
    Please refer to the attached sample project showing both of the above approaches - FlexChartMultipleSeries.zip
  • Posted 12 June 2025, 10:26 am EST - Updated 12 June 2025, 10:31 am EST
    Doesn’t work
  • Posted 13 June 2025, 3:15 am EST
    The RenderSymbolEventArgs.Item property used in the SymbolRendering event returns the current data item being rendered from the FlexChart’s DataSource. In our sample project, we used a List(Of PointF) as the data source, which is why the code casts e.Item to PointF.
    However, it appears you’re using a DataTable as the DataSource for your FlexChart. In that case, you’ll need to cast e.Item to DataRowView and then retrieve the required value from the underlying data row.
  • Posted 13 June 2025, 6:52 am EST
    Thank you,
    I’ve noticed that in your example, both the bar and line series use the same data for X and Y values.
    However, in my case, I need to display different X and Y data for the bar series and the line series.
    In C1Chart, this was possible by using ChartGroups(0) and ChartGroups(1), where I could assign different data sources to each group, and they would display correctly on the same chart.
    Is there a way to achieve the same behavior in FlexChart, i.e., using different X/Y data for the bar series and the line series and having them overlap correctly on the same chart?
    Thank you in advance for your help!
  • Posted 16 June 2025, 2:46 am EST
    Yes, you can use a different DataSource for each series in the FlexChart. Instead of setting the chart-level FlexChart.DataSource property, you can assign individual data sources using the Series.DataSource property for each series.
    Please refer to the updated sample project - FlexChartMultipleSeries_DataSource.zip
