It gets 5 minutes to open VBScript editor on C1FlexReport
Posted by: yasuike-na on 4 June 2019, 12:34 am EST
    Posted 4 June 2019, 12:34 am EST
    Hello.
    It gets 5 minutes to open VBScript editor at my environment.
    Is it abnormal? or Are there any way to speed up?
    Thanks in advance.
    Best regard.
    Naoki.
  • Posted 4 June 2019, 5:33 am EST
    What’s the ComponentOne version installed in your machine?
    Also, please share your environment details as opening VBScript Editor generally takes only a few seconds to open. At my end (Win10 version 1803) it took around ~2-3 sec to open up.
    Ruchir
  • Posted 4 June 2019, 10:05 pm EST
    Hi, Ruchir.
    Wow good to know that!
    We team members would yelled if it cleared!
    Our environment is,
    ComponentOne 4.0.20172.271
    on VisualStudio Pro 2017 version 15.7.4
    on Windows7 Pro SP1 64bit (4G RAM)
    on VMWare Workstation 14 Player
    on Windows10 Pro
    on ThinkPad E570 Corei5-7200U 2.5GHz + 8G RAM
    Best regards.
    Naoki
  • Posted 5 June 2019, 3:41 am EST
    For me, it is as fix as for Ruchir - even in version 2.0172.271.
    Does it happen for all kind of scripts or only for a single script? 32 or 64 bit version of the designer? Does it happen also when opening the file “FlexCommonTasks.flxr” in “%USERPROFILE%\Documents\ComponentOne Samples\WinForms\C1FlexReport\CS\FlexCommonTasks”?
  • Posted 6 June 2019, 10:32 am EST
    Using your environment too the issue does not occur for us.
    In addition to the questions by Wolfgang, can you please check if the VbScriptEditor degrades for the reports shipped along with the product samples? Or it specific to some of your reports? If yes, then we need you to share the report with us in order for us to investigate this further.
    ~Ruchir
  • Posted 6 June 2019, 9:45 pm EST
    I’m getting understand that it occuers only in my project,
    It was OK when I open the sample project,
    and my project is… I’m now converting an Access system into VB.NET and it’s with so many report formats and many items in each report.
    If there is a optimization way or defragging way, I’d be happy.
    Best regards.
    Naoki
  • Posted 7 June 2019, 6:43 am EST
    Sorry, but there is no such way(exposed) to reduce the time VBScriptEditor takes to open.
    However, if you can share your report then we can discuss this with the developer and investigate if there is anything that can be done to resolve the issue for you.
    If you’re not comfortable sharing the report in public then you can create a ticket at
    SupportOne(https://supportone.componentone.com/login).
    Best wishes,
    Ruchir
  • Posted 11 June 2019, 8:51 pm EST
    Thank you Ruchir,
    I’ve got a ticket and uploaded the report file.
    Best regards,
    Naoki
  • Posted 13 June 2019, 12:25 am EST
    Thank you Naoki. I have got your ticket.
    Will look into the report and respond you over there.
    Kind Regards,
    Ruchir
