Licensing ,net winform app for distribution
Posted by: arunoday.choudhury on 15 September 2020, 2:55 am EST
  • Posted 15 September 2020, 2:55 am EST
    I have a dev license and i am the only one who works on Active Reports v14. We have a .Net assembly which refers to all the grapecity dlls and i compile it on my machine. The application uses this dll to generate reports.
    How do i license the application?
    Arun
  • Posted 16 September 2020, 4:42 am EST
    Please follow the following steps to license your application
    1: Run cmd as administrator
    2:Switch to C:\ProgramData\GrapeCity\gclm folder
    3: Enter the following: gclm.exe “de456e2c-d2e3-4246-94e8-9648bbd6fbf0” -lc ./.gclicx [entry application name].[assemblyname].dll"
    4: Check that .gclicx file is generated in C:\ProgramData\GrapeCity\gclm folder.
    5: Open the project in which AR assemblies is used
    6: Add .gclicx file to the above project and make it embedded.
    7: Fix references, build and run MainExeceutable project
    Hope it helps.
  • Posted 6 October 2020, 4:34 pm EST
    Mohit Many Thanks for your response. The licensing seems like it might be working but I will have to test it out on a different client machine.
    I am now facing another issue. On Export to pdf I am getting this exception thrown and I have no clue why it is trying to refer v3.1.0.519.
    We have the following code and it is working with v12 of AR. But when I upgraded to v14, the export throws the following error. Can you please help?
    Unable to view requested report: . Error showing report viewer window. Unable to view requested report: Order - Summary/Item Detail. Could not load file or assembly ‘GrapeCity.Documents.Pdf, Version=3.1.0.519, Culture=neutral, PublicKeyToken=d55d733d2bfd5065’ or one of its dependencies. The system cannot find the file specified.
    Private Sub ExportReport()
        Const FILE_EXTENSION As String = "pdf"
        dlgSaveFile.Filter = "PDF Files (*.pdf)|*.pdf"
        Dim pr As New PageReport()
        Dim defaultPath As String = My.Computer.FileSystem.SpecialDirectories.MyDocuments
        'Everyone should have a my documents directory. This is an attempt to fix
        'this for one guy who seems to not have it.
        If Not My.Computer.FileSystem.DirectoryExists(defaultPath) Then
            defaultPath = My.Computer.FileSystem.SpecialDirectories.Desktop
        End If
        dlgSaveFile.FileName = My.Computer.FileSystem.CombinePath(defaultPath, _
            m_sDefaultExportFileName.Trim & "." & FILE_EXTENSION)
        If dlgSaveFile.ShowDialog() = Windows.Forms.DialogResult.OK Then
            PdfExport2.Export(repViewer.Document, dlgSaveFile.FileName)
        End If
    End Sub
  • Posted 7 October 2020, 3:28 am EST
    Could you please check the issue with the latest hotfix:
    http://cdn.grapecity.com/ActiveReports/AR14/Hotfixes/ActiveReports-v14.2.20540.msi
  • Posted 7 October 2020, 3:48 pm EST
    Thanks once again Mohit, the hotfix worked with the exception for export.
    Question -
    I have multiple applications(.exe(s)) which uses that one dll that has the .gclix embeded, but each time I have to run the gclm command for each of those applications to create a new .gclix file and then embed in to the dll project and recompile it. Is there a better way to do this which minimizes this task of recreating the .gclix for each application?
    Thanks with Regards
    Arun
  • Posted 8 October 2020, 5:49 am EST
    I have asked the development for the same and will inform you once I get any information from them.
  • Posted 8 October 2020, 12:03 pm EST
    I have replied your query on the following SupportOne case:
    https://supportone.componentone.com/home/casedetail/466877
    You can login to SupportOne with same forum credential. Please reply to the SupportOne case only to avoid confusion.
