LineMarker.Content Property (C#)
Posted by: richard.sadler on 7 February 2018, 2:44 pm EST
    Posted 7 February 2018, 2:44 pm EST
    Hi
    I want to format the content of a line marker data label using function set using the linemarker.content property.
    I’m assuming it needs to be delegate function, but information on using this isn’t obvious to me.
    I get that you can just name the properties of the data that the data series is bound too, but I want to be able to format the data myself
    can anyone help with an example (other than that already available in the flexchart documentation)
    thanks
    Richard
  • Posted 8 February 2018, 12:14 am EST
    Hi Richard,
    The LineMarker.Content requires a string value and not a delegate. This string can contain some pre-defined keywords which the chart would replace at run-time. This is similar to what we have for Toolip customization.
    http://help.grapecity.com/componentone/NetHelp/FlexChartWin/webframe.html#CustomizingTooltipContent.html
    For formatting the LineMarker’s content we’d suggest you to check the LineMarkerExplorer sample. It demonstrates various options using which the LineMarker content can be customized.
    https://www.grapecity.com/en/samples/linemarkerexplorer
    Let us know if this helps.
    Ankit
  • Posted 12 February 2018, 3:56 pm EST
    Hi Ankit
    thanks, that helped me get the formatting I wanted
    regards
    Richard
