Posted 16 January 2020, 3:14 pm EST
After reading the article below, I have a rough idea of the benefits in terms of performance/rendering between C1 and Flex.
https://www.grapecity.com/blogs/net-reporting-faster-rendering-and-exporting-with-new-flexreport
Question 1) In terms of memory usage, do you also have a article regarding this matter ? Is Flex using less, more or the same amount of memory compared to C1 ?
Second, I’m aware that C1MultiDocument is no longer supported and because of that I’m also migrating that. However, I have the following line of code
C1MultiDocument mltDocument = new C1MultiDocument();
mltDocument.SetStorage(C1.C1Preview.StorageType.Disk);
Question 2) I could not find an equivalent method of SetStorage() in Flex. Is there an similar method ?
Question 2.1) Does that mean that everything is stored in memory ?
Question 2.2) If there is not similar method, does that mean it’s no longer a point of attention ?
