Merged FlexReports - Missing pixels
Posted by: thomas.hayashi on 27 December 2019, 9:14 am EST
    Posted 27 December 2019, 9:14 am EST
    Thanks to this thread, I’m able to perform a merge with multiple reports
    https://www.grapecity.com/forums/winforms-edition/merging-multiple-flexrepor
    I’m not using the exact provided code , however I can see a difference between exporting the original report and the merged one. For now, I only have one example. The export_merged.pdf is cutting some pixels on the word “CORTESIA” (below the word Convênio, in the header). While the exact same report exported by itself, does not have those pixels cut off.
    I’m using the following code
    // Exporting by itself
    C1FlexReport c1FlexReport1 = new C1FlexReport();
    c1FlexReport1.Load("..\\..\\1_00001#15684563#CORT^CORT.flxr", "0 - Laudos");
    C1.Win.C1Document.Export.PdfFilter exp = new C1.Win.C1Document.Export.PdfFilter();
    exp.FileName = "export_single.pdf";
    c1FlexReport1.Export(exp);
    //Exporting merged. Even though here is just one report
    List<C1FlexReport> lstRep = new List<C1FlexReport>();
    lstRep.Add(c1FlexReport1);
    C1FlexReport mergeFlex = new C1FlexReport();
    mergeFlex.Sections.PageFooter.Height = 0;
    mergeFlex.Sections.PageHeader.Height = 0;
    mergeFlex.Sections.Header.Height = 0;
    mergeFlex.Sections.Footer.Height = 0;
    mergeFlex.Layout.MarginBottom = 0;
    mergeFlex.Layout.MarginLeft = 0;
    mergeFlex.Layout.MarginRight = 0;
    mergeFlex.Layout.MarginTop = 0;
    mergeFlex.Sections.Detail.AutoHeight = AutoSizeBehavior.GrowAndShrink;
    mergeFlex.Sections.Detail.Visible = true;
    foreach (C1FlexReport flex1 in lstRep)
    //OBS: WITHOUT THIS RENDER THE PAGE COUNT IS ALWAYS ZERO. IS THIS CORRECT ?
        flex1.Render();
        for (int i = 0; i < flex1.PageCount; i++)
            SubSection section = mergeFlex.Sections.Detail.SubSections.Add();
            section.Visible = true;
            section.Height = mergeFlex.Layout.PageSize.Height;
            section.AutoHeight = AutoSizeBehavior.None;
            ImageField img = new ImageField();
            img.Picture = flex1.GetPageImage(i);
            img.Left = 0;
            img.Top = 0;
            img.AutoWidth = AutoSizeBehavior.CanGrow;
            img.AutoHeight = AutoSizeBehavior.GrowAndShrink;
            section.Fields.Add(img);
    C1.Win.C1Document.Export.PdfFilter exp2 = new C1.Win.C1Document.Export.PdfFilter();
    exp2.FileName = "export_merged.pdf";
    mergeFlex.Export(exp2);
    I’m afraid that my clients have custom reports and after doing this merge the final version it’s gonna be different. So I’m asking if Is there a way around the code, without touching the report ? Or Am I missing something here ?
    I’m using the 4.0.20193.393 version
    Missing_pixels_merged_flexreport.zip
  • Posted 30 December 2019, 5:20 am EST
    I could observe the missing pixels in the merged report’s PDF export and am investigating on this further(Internal Tracking ID: 414999). Will get back to you once it is done.
  • Posted 8 January 2020, 4:29 pm EST
    Given that we also work under a schedule, I was asked to check the progress of this thread.
    So is there a estimate date for this ?
  • Posted 9 January 2020, 7:25 am EST
    As per the development team, the issue cannot be completely fixed. It has been partially fixed in an internal build. ETA for the release of the same is end of March.
    Regards.
  • Posted 14 January 2020, 11:28 am EST
    Hi, thanks for your reply
    I’m afraid that the project cannot wait until end of March to be released. Is there any alternative to this ? It’s just a few pixels.
  • Posted 15 January 2020, 11:35 pm EST
    Hi Thomas,
    The team is working to generate a private build for you.
    I will get back to you when we have it ready. I assure that it’ll be soon.
    Regards.
  • Posted 29 January 2020, 5:41 am EST
    The private build has been shared over SupportOne: https://supportone.componentone.com/casedetail/418778.
    Please login using the same credentials you use here on the Grapecity website.
    Regards.
  • Posted 29 January 2020, 9:41 am EST
    I’ve updated and was able to render correctly. Thank you very much esha.dhir and the team.
  • Posted 18 March 2020, 6:59 am EST
    I am glad to inform you that the issue has been fixed in the latest release build (i.e. 2020v1). You can get it from the links below:
    http://prerelease.componentone.com/dotnet40/c1winforms/2020-t1/C1WinForms.4_4.0.20201.416.zip
    http://prerelease.componentone.com/dotnet452/c1winform/2020-t1/C1WinForms-452_4.5.20201.416.zip
    Pragati
