Migrate to another PC license of spread 12
Posted by: jbingenieriasoftware1921 on 7 March 2020, 11:59 am EST
    Posted 7 March 2020, 11:59 am EST - Updated 4 October 2022, 12:03 am EST
    With the licence at another PC
    I view it
    error when I copy a project and compile solution
    Severity Code Description Project File Line Status deleted Status deleted
    Error CS1061 “FpSpread” does not contain a definition for “GetSheet” or an accessible extension method “GetSheet” that accepts a first argument of type “FpSpread” (is any directive missing using or an assembly reference?)
  • Posted 9 March 2020, 12:34 am EST - Updated 4 October 2022, 12:04 am EST
    Can you please check the version of the assembly ‘FarPoint.Win.Spread’ referenced in your assembly? You can see the version from the Properties window (as shown in attached screenshot).
    Your project is probably referencing an older version of the assembly.
    Jitender
  • Posted 14 March 2020, 1:16 pm EST
    thanks is ready
    I deleted DLL and re-created it
  • Posted 21 March 2020, 5:56 pm EST
    I compile without error but When I open the app received same error on Execution time.
  • Posted 21 March 2020, 6:10 pm EST
    System.MissingMethodException: ‘Método no encontrado: ‘FarPoint.Win.Spread.SheetView FarPoint.Win.Spread.FpSpread.GetSheet(Int32)’.’
  • Posted 21 March 2020, 6:36 pm EST - Updated 4 October 2022, 12:04 am EST
    I create a new one form
    If I drag and drop on form component FpSpread Received this error
  • Posted 23 March 2020, 5:59 am EST
    Can you please attach a small test project so we can investigate it?
    Jitender
  • Posted 23 March 2020, 12:23 pm EST
  • Posted 23 March 2020, 12:59 pm EST
    I have to delete some dll
  • Posted 23 March 2020, 2:08 pm EST
    I create a new one project on the PC with license
    and copy project to another one PC with same license and compile succesfully but not run
    + $exception {“Método no encontrado: ‘FarPoint.Win.Spread.SheetView FarPoint.Win.Spread.FpSpread.GetSheet(Int32)’.”} System.MissingMethodException
    I used 12.45.20181.0 both PC’s
  • Posted 23 March 2020, 2:16 pm EST
    Here is Computer 1 and Computer 2
  • Posted 23 March 2020, 2:18 pm EST - Updated 4 October 2022, 12:04 am EST
  • Posted 23 March 2020, 9:23 pm EST - Updated 4 October 2022, 12:04 am EST
    It is only possible to create new projects, if we compile in a diferent machine it generates the error that we have sent to you before.
    We are trying to create a backup machine but hte backup project does compile on the new machine but it doesn’t run properly ( it displays the error tah we sent today earlier )
  • Posted 24 March 2020, 3:13 am EST
    Can you please try changing ‘Specific Version’ to False?
    And don’t reference the assemblies in your backup machine from the ‘bin’ directory.
    Once you’ve changed ‘Specific Version’ to false, the copied project when opened in the backup machine should correctly pick the required assemblies from the installed location.
    Jitender
