Moving appointments in c1Schedule
Posted by: gessi on 29 September 2017, 2:39 am EST
    Posted 29 September 2017, 2:39 am EST
    Hi
    How can I move or insert an appointment between two existing appointments? When I try to move an appointment on a position where an appointment is placed, both are reordered horizontally. But this is not what I want. I want to insert the appointment between two existing ones.
    best regards
    Peter
  • Posted 3 October 2017, 8:05 am EST
    Hi Peter,
    The scenario you are describing happens when the appointment dragged/dropped has its End greater than the Start of the below existing appointment.
    If you need to change this behavior, then you may use C1Schedule1_BeforeAppointmentDrop event and manually change the Start of the existing appointment.
    Ruchir Agarwal
