Multi-threading C1Report instances
Posted by: dthomas on 30 January 2020, 12:43 pm EST
    Posted 30 January 2020, 12:43 pm EST
    We’re still using the old C1Report effectively. However, we’re creating multiple instances of C1Report objects at the same time, in different threads (one in each thread). I’m assuming C1Report is thread safe. Is that correct?
  • Posted 31 January 2020, 6:59 am EST
    I am investigating on the same internally and will get back to you once it is done.
  • Posted 5 February 2020, 4:36 am EST
    As long as you are not using the same instance of C1Report in different threads without synchronizing access, things will work fine and multi-threading will be supported.
