Need Help in exporting to Excel
Posted by: kjalmeraikhi on 6 July 2021, 9:17 am EST
  • Posted 6 July 2021, 9:17 am EST
    hello
    I am new to C1 and I am facing an issue in exporting to Excel I have followed the examples in the documents however every time I run my application and try to run the code I get a exception “Invalid parent style (null or different context)” and that is it nothing else. I am at the latest VS and C1 using .net 4.5 can you help me please.
  • Posted 7 July 2021, 12:21 am EST
    Could you please let us know which C1 control are you facing this issue with and if possible, can you please provide a small sample replicating the issue?
    Regards.
    Avnish
  • Posted 2 September 2021, 8:49 am EST
    I have the same error when exporting from webform/flexgrid saveAs excel. The form would have multiple grids and it looks like the issue with the the CellStyle(?).
    I can’t pinpoint for sure the exact issue but the error that comes back is “Invalid parent style (null or different context)”.
  • Posted 2 September 2021, 9:08 am EST
    I’m getting the error in C1FlexGrid.SaveGrid() when saving as excel
  • Posted 3 September 2021, 12:51 am EST
    Hi Jenn,
    We have replied to your “My Support” case regarding the same issue. Please continue the thread there.
    Avnish
  • Posted 26 January 2022, 8:25 am EST
    Hi Avnish.
    we have the same problem.
    https://www.grapecity.com/forums/winforms-edition/need-help-in-exporting-to-#hi-jennwe-have-replied-to-
    Can you share the solution?
    Vito
  • Posted 27 January 2022, 12:45 am EST
    Hi Vito,
    The “Invalid parent style (null or different context)” error usually occurs when you have used CellStyle of one FlexGrid in another FlexGrid. Please make sure you are not doing the same in your application.
    If you still face the issue, please share a sample on the support case [Case ID CAS-28560-J8M9V1] we have created for you. The support portal is private so you can share information there without worrying.
    Avnish
