[NET6] Resetting column datatype is not possible
Posted by: wknauf on 18 July 2023, 4:36 am EST
    Posted 18 July 2023, 4:36 am EST - Updated 13 August 2025, 11:10 am EST
    See attached sample: try to reset the datatype of column 1 to “Object”. This is not possible, it jumps back to the current value “Boolean”:
    FlexGridColumnDataType.zip
    You have to edit the resx file.
  • Posted 18 July 2023, 5:59 am EST
    Same for the width: it you have set a width before, you cannot reset it to “-1” by designer.
  • Posted 18 July 2023, 7:03 am EST - Updated 13 August 2025, 11:10 am EST
    …and same for the caption.
    Resetting the caption and the datatype works in the “C1FlexGrid tasks” popup:
  • Posted 18 July 2023, 9:07 am EST
    Hi Wolfgang,
    Thank you for providing all the details. We could see the behavior you mentioned with the C1FlexGrid Designer. We have reported the issue to the development team and will let you know the updates soon.
    [Internal Tracking ID: C1WIN-30742]
    Best Regard,
  • Posted 7 August 2023, 9:26 am EST
    It seems this was fixed in .611 - maybe by https://www.grapecity.com/forums/winforms-edition/flexgrid-column-designer-in-588-invisible-columns-and-default-values ?
    Could you confirm this? I cannot reproduce the issue with .611.
  • Posted 8 August 2023, 3:09 am EST
    Hi Wolfgang,
    We tested the issue with the latest 2023v2(611) release, and it appears to be resolved. We are getting in touch with the development team to confirm this and will let you know as soon as possible.
  • Posted 21 September 2023, 9:52 am EST
    Hi Wolfgang,
    As per the development team, this issue was fixed with the escalation C1WIN-29290 done for (https://www.grapecity.com/forums/winforms-edition/flexgrid-column-designer-in-588-invisible-columns-and-default-values).
    Kind Regards,
