New Ribbon does not support icons from project resources
Posted by: wknauf on 16 February 2022, 5:42 am EST
    Posted 16 February 2022, 5:42 am EST - Updated 13 August 2025, 11:09 am EST
    just noticed that the new ribbon in 4.5.20213.539 does not support images that are placed in “Properties\Resources.resx”.
    I can add them by picking them from the resource file:
    But the generated code looks like this:
    this.ribbonButton1.IconSet.Add(new C1.Framework.C1BitmapIcon(null, new System.Drawing.Size(16, 16), System.Drawing.Color.Transparent, ((System.Drawing.Image)(resources.GetObject("ribbonButton1.IconSet")))));
    And the image is duplicated to the current form resx file.
    I would expect:
    this.ribbonButton1.IconSet.Add(new C1.Framework.C1BitmapIcon(null, new System.Drawing.Size(16, 16), System.Drawing.Color.Transparent, ((System.Drawing.Image)(global::RibbonIconSet.Properties.Resources._3d_glasses_16))));
    See attached sample: RibbonIconSet.zip
    I consider this a major problem for us, because:
    a) you cannot browse for usage of images in the global “Resources.Designer.cs” file.
    b) you cannot modify/replace the image, as they are all duplicated
    c) as they are duplicated, the resulting exe file will be larger.
    Workaround: find all usages and change them manually.
    Strange enough, when opening an old ribbon form with “SmallImage/LargeImage” properties in designer, it is converted to the new “IconSet”, and here the global resource file works as expected. It happens only for newly added icons.
    Please fix this as soon as possible.
  • Posted 17 February 2022, 7:02 am EST
    We have forwarded your request to the development team and will let you know as soon as we have an update.
    Avnish
    [Internal Tracking ID : C1WIN-26828]
  • Posted 20 June 2022, 5:23 am EST
    Any updates on this?
  • Posted 20 June 2022, 6:20 am EST
    Hi Wolfgang,
    We are getting in touch with the development team to get an update on this issue. We will update you as soon as possible.
    Kind Regards,
  • Posted 20 June 2022, 11:14 pm EST
    Hi Wolfgang,
    As per the development team, the ETA for the issue fix is the 2022v2 hotfix release.
    Kind Regards,
  • Posted 26 September 2022, 8:02 am EST
    Hi Wolfgang,
    We are glad to let you know that this issue has been fixed in the latest 2022v2 hotfix release (4.5.20222.576).
  • Posted 26 September 2022, 8:50 am EST
    Great, I can confirm that my sample works now. Many thanks!
