Object reference not set to an instance of an object when deleting C1Editor
Posted by: matti.saarenketo on 9 January 2019, 6:51 am EST
    Posted 9 January 2019, 6:51 am EST
    Installed C1 Version 4.0.20183.338
    Steps to reproduce
    1. Open visual studio 15.9.5
    2. File → New Project
    3. Windows Forms App (.NET Framework)
    4. Project name: DeleteC1EditorTest
    5. .NET Framework 4.6.1
    6. OK
    7. Toolbox → C1 WinForms 4.0 → C1Editor
    8. Add that to the created Form1.vb
    9. Press delete after adding it
    Expected result: The created C1Editor is removed from Form1
    Actual result: A Microsoft Visual Studio dialog pops up: “An Error occured while processing this command. Object reference not set to an instance of an object”
    DxDiag log:
    DxDiag.zip
  • Posted 10 January 2019, 1:42 am EST
    Thanks for reporting the issue. I could observe the same at my end and have forwarded it to the concerned team [Internal Tracking ID: 361377]. Will get back to you once I have any information on this.
  • Posted 14 January 2019, 6:09 pm EST
    Hi Matti, thanks for finding it. This bug will be fixed in the first 2019 v1 build.
    • Alexey.
  • Posted 3 April 2019, 1:31 pm EST
    The issue is fixed with the latest release version. You can either update using C1Live or manually download the assemblies from here: http://prerelease.componentone.com/dotnet40/c1winforms/2019-t1/C1WinForms.4_4.0.20191.359.zip
    To learn how to use C1Live, please refer https://www.grapecity.com/en/support/c1live
    Ruchir
