OLAP, can I show the selectable columns non sorted by name
Posted by: peter.grefberg on 16 October 2017, 9:29 am EST
    Posted 16 October 2017, 9:29 am EST
    I would like the list of all columns in my Data table shown in exact the same order as they are in the result set, not sorted alphabetically.
    Is it possible?
    I am using C1OlapPage.
    thanks in advance
    Peter
  • Posted 17 October 2017, 11:47 pm EST
    Hi Peter!
    It won’t be possible to change the order of fields in any other manner here. However, you can let us know if you face any other issue.
    Meenakshi
  • Posted 25 September 2019, 6:56 am EST
    What is the status on this one?
    I want the available columns sorted in the same order as in the dataset.
    The first column in the dataset, is the first column to select, and so on.
    Dont want/need it to be sorted from A-Z, just the order in my dataset!
    //Peter
  • Posted 27 September 2019, 5:28 am EST
    I want to inform you that Olap is obsolete now. There is new control “FlexPivot” introduced in replacement of C1Olap. To know more about the FlexPivot, please refer to the following documentation link:
    https://help.grapecity.com/componentone/NetHelp/c1flexpivot/webframe.html#FlexPivotOverview.html
    Here, you can create the PreDefine view as mentioned in the following documentation link:
    https://help.grapecity.com/componentone/NetHelp/c1flexpivot/webframe.html#AddingPredefinedViews.html
    Hope it helps.
