Open WinForm containing C1TrueDBGrid show Unsaved, OnAddNew not active 2nd time
Posted by: goyal.alokk on 13 December 2019, 5:58 am EST
  • Posted 13 December 2019, 5:58 am EST
    Used C1TrueDBGrid:- Version=4.0.20183.338 in my application, if I open a WinForm containing C1TrueDBGrid then show form Unsaved. In our running program, 1st start C1TrueDBGrid adds or update value no problem, add/ update success. In 2nd time C1TrueDBGrid OnAddNew mode not running. Then delete 1st row then OnAddNew activate. What is my problem? How to solve this?
  • Posted 13 December 2019, 6:59 am EST
    The first issue is a known bug [Internal Tracking ID: 382525]. We’ll update this thread once a fix for this is available.
    I could not observe the second issue. Can you please attach your sample or modify the attached sample so we can observe the same at our end?
    AddNewMode.zip
    Jitender
  • Posted 14 December 2019, 2:32 am EST
    Start entry when last column press save, then start new entry grid last column pressed but it stacked, if I delete this and start entry then not stacked. Another issue, what is the procedure to reactive component one when machine window reinstalled?
  • Posted 16 December 2019, 12:42 am EST
    I’m sorry, I could not understand the reproducing steps. Can you please make a GIF or a small video showing the steps so I can also replicate it?
    If you want to activate ComponentOne on a fresh Windows installation, make sure that you have deactivated the license from your old installation. One license can be used on 2 machines. [See this page for more info: https://www.grapecity.com/licensing/componentone].
    Once deactivated, you can activate C1 on your new installation with the same key.
    Jitender
  • Posted 16 December 2019, 3:09 am EST - Updated 3 October 2022, 11:46 pm EST
  • Posted 16 December 2019, 4:34 am EST
    The GIF file you’ve attached is a static image so I’m unable to see the steps you are taking. Can you please explain the steps you are taking? What do you mean by ‘stacked’? What’s ‘press save’? Are you referring to the ‘Save’ button, or just getting out of edit mode?
  • Posted 16 December 2019, 8:50 am EST - Updated 3 October 2022, 11:46 pm EST
    Probably my person has not been able to explain you the problem we are facing which have started only since few week, however it was working fine since so many years.
    Please refer the Grid attached where the last active column has been circled and the grid is working under auto update mode. The columns after the circled one are only display columns and are not active in the grid.
    The problem we are facing is
    When the form is loaded and a record is being added the row in the grid gets added automatically after the last circled column has been edited but after saving the the record during addition on next record the row fails to get added automatically after last column edit. When we delete this unfinished row, the problem gets solved.
    What could be the sudden reason for this problem which we are using since so many years without any trouble
    no codes written for any events of this last columns
    IN OTHER WORDS NEW ROW IS FAILED TO GET ADDED FOR THE NEXT RECORDS AND THIS HAS STARTED IN ALL THE GRID BASED FORM WE ARE USING.
  • Posted 17 December 2019, 12:59 am EST - Updated 3 October 2022, 11:46 pm EST
    Thanks for the explanation. I understand the issue now, however, I still could not observe said behavior. See attached GIF file for my observations:
    Please attach a small sample where this issue can be observed so we can assist you accordingly.
    Jitender
  • Posted 19 December 2019, 6:11 am EST
    please find attached a sample projects with single form live with database for you to check
    regards
  • Posted 19 December 2019, 6:24 am EST
    It seems the sample was not attached correctly.
    Please make sure that the sample is archived in a zip file (only images and zip files can be attached).
    Jitender
  • Posted 19 December 2019, 8:25 am EST
    AgshWinTrueDBGrid.zip
    could not add component dll due to size restriction
  • Posted 20 December 2019, 5:12 am EST - Updated 3 October 2022, 11:46 pm EST
    I still can’t observe any issues with your sample.
    See the attached GIF for my observations:
    Jitender
  • Posted 9 July 2020, 6:51 am EST
    The fix for the issue where TrueDBGrid shows an unsaved icon on Form designer is available in the latest hotfix update (*.424 builds).
    You can update your controls using ComponentOne Control Panel (https://www.grapecity.com/blogs/welcome-to-componentone-controlpanel).
    Jitender
