Posted 20 September 2021, 3:23 am EST
Dear Sir/Mam,
Whenever I try to call FlexReport.Print();
the above error occurs…
Please help us…
Regards-
Sanjeeb
Posted by: sanjeeb.srjm on 20 September 2021, 3:23 am EST
Dear Sir/Mam,
Please help us…
Regards-
Sanjeeb
Posted 21 September 2021, 6:39 am EST
Hello Sanjeeb,
Would you please use the Generate method of FleReport before printing and try again? If the issue still occurs then, please let us know.
FlexReport.Generate()
FlexReport.Print(result);
Posted 21 September 2021, 6:54 am EST - Updated 3 October 2022, 10:41 pm EST
Posted 22 September 2021, 6:58 am EST
Hello Sanjeeb,
As per your first post, it seems that you are using the code:
FlexReport.Print()
But for the case of printing directly, the C1PrintOptions instance is used. When you want to print the reports directly without showing all the settings behind the printing process, the Print methods of FlexReport with C1PrintOptions come to the rescue. So, please use the code snippet given below:
Render();
C1PrintOptions result = new C1PrintOptions();
result.PrinterSettings = new PrinterSettings();
result.PrinterSettings.PrinterName = "EPSON L360 Series";
https://www.grapecity.com/blogs/create-custom-print-dialog-print-directly-from-flexreport
Posted 22 September 2021, 7:44 am EST
Dear Prabhat Sir,
I have used exactly you suggested like:-
Render();
result.PrinterSettings.PrinterName = “EPSON L360 Series”;
But still shows the printing dialog …
Regards-
Sanjeeb
Posted 23 September 2021, 6:12 am EST
It seems that this is happening because of your printer settings, as we do not face the issue at our end. Would you please try with any other printer and see if the same issue persists.
Also, if you still face the issue, please share a GIF of the process and your printer details.
Posted 26 September 2021, 12:58 am EST
Dear Prabhat Sir,
I have tried the same in two printers located at two destination…
but same dialog still popups as shown in above snapshot…
Sir, in this mode We are unable to print in Landscape mode.
we have tried doing followings but couldn’t :-
In short, only preview mode works for Landscape, not direct printed by flexreport…
result.PrinterSettings.DefaultPageSettings.Landscape = true;
result.PageSettings.Landscape = true;
Layout l = FlexReport.Layout;
l.PaperSize = System.Drawing.Printing.PaperKind.A4;
l.Orientation = OrientationEnum.Landscape;
FlexReport.PageSettings.Landscape = true;
but nothing working…
Regards-
Sanjeeb
Posted 27 September 2021, 7:40 am EST
Hello Sanjeeb,
As per your given screenshot, it seems that you are getting this dialog while printing, so this setting is specific to your printer driver.
The specific code to print the report in landscape mode via code is given below:
result.PrinterSettings = new Printing.PrinterSettings();
C1FlexReport1.Layout.Orientation = C1.Win.FlexReport.OrientationEnum.Landscape;
C1FlexReport1.Render();
C1FlexReport1.Print(result);
If this does not help, please let us know why you are using the silent printing mode at your end?
Posted 28 September 2021, 10:35 pm EST
Dear Prabhat Sir,
Can you please send me the sample project which is printing silently
and also working in Landscape mode ?
So, that we can compare the difference with our code and dictate accordingly ?
Please sir…
Regards-
Sanjeeb
Posted 29 September 2021, 7:15 am EST
Posted 29 September 2021, 10:41 am EST
Dear Prabhat Sir,
now looking towards your code we achieved landscape but working for only A4 Size not for Bank Cheque Paper Size (3.5X7.2)
when we set custom size like below no custom size printing is being done…
FlexReport.Layout.Orientation = C1.Win.FlexReport.OrientationEnum.Landscape;
FlexReport.Layout.PaperSize = PaperKind.Custom;
FlexReport.Layout.Width = 5040; //3.5 inch into twips
FlexReport.Layout.CustomWidth = 5040;
FlexReport.Layout.CustomHeight = 10368; //7.2 inch into twips
FlexReport.Render();
FlexReport.Generate();
Please help to print on custom size …
Regards-
Sanjeeb
Posted 1 October 2021, 5:33 am EST
Hello Sanjeeb,
We are discussing this with the developers and will get back to you with the updates soon.
[Internal Tracking ID: C1WIN-25790]
Posted 3 February 2022, 5:50 am EST
Dear Sir,
Still waiting your kind support.
sir, for winform standard silent printing we are using
printDocument1.PrintController = new StandardPrintController();
which is perfectly working…
Regards-
Sanjeeb
Posted 7 February 2022, 7:19 am EST
Hello Sanjeeb,
As per the devs to set the custom page size via code to print silently via FlexReport use the code snippet given below:
result.PrinterSettings = new System.Drawing.Printing.PrinterSettings();
PaperSize ps = new PaperSize("Custom", 100, 100);
result.PrinterSettings.DefaultPageSettings.PaperSize = ps;
