PrintDocument with C1FlexViewer
Posted by: jong on 19 June 2018, 12:30 pm EST
    Posted 19 June 2018, 12:30 pm EST
    We have an application that uses C1.C1Report.4 to produce various reports and show them in a Form containing a C1.Win.C1Preview.C1PrintPreviewControl. I would like to upgrade this application to use C1FlexReport and C1FlexViewer, which I should be able to do without much difficulty.
    However, the same application uses a third-party word-processing control to produce a System.Drawing.Printing.PrintDocument. The application then shows the PrintDocument in the same form containing the C1.Win.C1Preview.C1PrintPreviewControl. Is there any way to use the newer C1FlexViewer to show the System.Drawing.Printing.PrintDocument produced by the third-party control?
    Jon
  • Posted 20 June 2018, 1:27 am EST
    As stated in the below mentioned documentation link, C1FlexViewer can be used to preview documents like C1Report, C1FlexReport, SSRS, and PDF:
    http://help.grapecity.com/componentone/NetHelp/FlexReport/webframe.html#FlexViewer.html
    Thus, PrintDocument cannot be directly previewed by C1FlexViewer. However, you can save the document to PDF to view it in the C1FlexViewer. The below mentioned link explains the same:
    http://help.grapecity.com/componentone/NetHelp/C1Document/webframe.html#PDFDocumentSource-Quick-Start.html
  • Posted 20 June 2018, 9:15 am EST
    Thanks. I will give it a go.
    Jon
  • Posted 23 March 2019, 7:47 pm EST
    I have a function that used to work with C1Report that returns ```
    System.Drawing.Printing.PrintDocument();
    //Setup the printer settings
    _rpt.Document.PrinterSettings.PrinterName = GetPrinter();
    _printDoc = _rpt.Document;
    //_rpt.Document.PrinterSettings.DefaultPageSettings.PaperSize = _rpt.Document.PrinterSettings.DefaultPageSettings.p
    return _rpt.Document;
    Is that possible with FlexReport?
  • Posted 25 March 2019, 3:30 am EST
    C1FlexReport.Document cannot be converted to System.Drawing.Printing.PrintDocument. PrintDocument should not be used with FlexReport since C1Flexreport.Document property does not return a PrintDocument.
    Hope it helps.
    Regards.
  • Posted 24 May 2019, 3:53 pm EST
    Esha,
    Are there any plans to upgrade C1FlexViewer so that it can use a PrintDocument as the preview document? This would make my conversion process so much easier.
    Jon
  • Posted 27 May 2019, 6:46 am EST
    Hi Jon,
    Sorry to mention that using PrintDocument in C1FlexViewer is not in the to-do list of the team.
    Let me know if you need further assistance.
