Problem to find column in C1Combo with IndexOf()
Posted by: thomas on 17 June 2020, 4:27 pm EST
    Posted 17 June 2020, 4:27 pm EST
    Hi
    Can’t get this to work:
    Dim dc As New C1DataColumn
    dc.DataField = “Kflag”
    Dim iCol = C1Combo1.Columns.IndexOf(dc)
    iCol is -1
    This works:
    Dim iCol As Integer = -1
    For i = 0 To C1Combo1.Columns.Count - 1
    If C1Combo1.Columns(i).DataField = “Kflag” Then
    iCol = i
    Exit For
    End If
    Next
    iCol is correct column.
    (Datasource is datatable)
    Must say I’m not sure about the use of C1DataColumn. In other controls it’s possible to use string in IndexOf, but in C1Combo it need to be C1DataColumn.
    I’m using ComponentOne Studio for WinForms (.NET 4.0) 4.0.20183.343
  • Posted 18 June 2020, 7:45 am EST
    Hi Thomas,
    The code snippet you used is creating a new instance of C1DataColumn which is not the part of C1Combo1. To get the correct column index use the code snippet given below:
    Dim iCol = C1Combo1.Columns.IndexOf(C1Combo1.Columns("Kflag"))
  • Posted 18 June 2020, 8:37 am EST
    Hi Prabhat!
    Great, thank you! :slight_smile:
    Now I only need to check if the column exists. In other C1-components it world return -1, but not in this one. How can I check that?
    Thomas Lindgren
  • Posted 19 June 2020, 12:31 am EST
    Hi Thomas,
    You can use the code snippet given below to check. whether the specified column exists or not:
     Dim colExist As Boolean = False
                If C1Combo1.Columns(i).DataField = "Field Name" Then
                    colExist = True
                    Exit For
                End If
            Next
            If colExist Then
                Console.WriteLine("Exists")
            Else
                Console.WriteLine("Does  not Exist")
            End If
