Problem with C1Sizer
Posted by: r.trofymchuk on 19 March 2018, 11:48 am EST
    Posted 19 March 2018, 11:48 am EST - Updated 4 October 2022, 12:51 am EST
    I have a form with a Panel and 2 FlexGrids in it. I need to resize one of the FlexGrid using c1Sizer and during resizing I get a black trail (mark) on FlexGrid from Splitter. Please find the example in the attached file.
  • Posted 20 March 2018, 1:03 am EST
    Hello!
    I created a very simple application as per the scenario (with build version 4.0.20181.296). But, I could not see the problem at my end. Attached is the sample for your reference.
    Prj_GridWithSizer.zip
    Kindly let me know if you are able to see the issue in this sample as well. If yes, I would request you to share the build version, environment details at your end.
    Best regards,
    Meenakshi
  • Posted 20 March 2018, 5:18 am EST
    Hi Guys,
    Unfortunatly, the issue still happens at my end (((
    The enviroment details are: Windows 10, VS 2017, 4.0.20181.296
    We have also tried at windows 8 VS 2010 and with version of Components 4.020173.286 - it also doesn’t work.
    And we have detected, that it works only with Windows 7.
    Also we are using Framework 4.
    Thanks for helping.
    With kindly regards,
    Roman
  • Posted 21 March 2018, 1:12 am EST
    Hi Roman!
    Yes, I can see the black trail issue on a specific version of Windows 10 + VS 2017, with the latest build. And, this has been reported to the development team [Internal Id : 314644].
    You will be notified once it is fixed.
    Best regards,
    Meenakshi
  • Posted 14 June 2018, 12:27 am EST
    Hello!
    While doing further investigation, it was observed that this issue is not reproducible with OS build 1803 of Windows 10.
    So I would suggest you to update your OS to this build, if possible for you.
    Let me know in case of any further assistance.
    Meenakshi
  • Posted 22 August 2019, 8:29 am EST
    Unfortunately, the old problem reappeared: during resizing I get a black trail (mark) on FlexGrid from Splitter.
    The enviroment details are: Windows 10, VS 2017, 4.0.20192.375
    Framework 4.
    Thanks for helping.
    Roman
  • Posted 23 August 2019, 1:53 am EST - Updated 4 October 2022, 12:51 am EST
    Hello Roman,
    Sorry but I could not replicate the issue at my end while resizing controls using the attached sample.
    I am attaching a GIF file for your reference please have a look.
    The environment details at my end are: Windows 10 Version 1803, VS 2017 Version 15.4.1 , Control Version 4.0.20192.375 , Framework 4.
    I have also checked this scenario with Windows 8.1 but it was working fine there as well.
    Can you please share version of your Windows machine in which you are facing the issue?
    Thanks and Regards,
    file-d41d1b30-9014-4403-9693-d8ccaff56b12.zip
  • Posted 23 August 2019, 5:38 am EST - Updated 4 October 2022, 12:52 am EST
    Hi Guys, the problem is still here ((( The environment details at my end are in printScreens
  • Posted 23 August 2019, 7:32 am EST
    The enviroment details are: Windows 10 Pro, Version 1903
    VS 2017, 4.0.20192.375 Framework 4.
  • Posted 26 August 2019, 6:47 am EST
    Thank you for sharing the environment details.
    We are investigating on this and will let you know once it is done.
  • Posted 27 August 2019, 2:20 am EST - Updated 4 October 2022, 12:52 am EST
    Hello Roman,
    We have checked the last attached sample in your suggested environment (Win 10 Version 1903) but could not replicate any issue.
    I am attaching a GIF file which shows that the last attached sample is working fine in Win 10 Version 1903 environment.
    If you are using any other sample, please share the sample so that we can help you with the best.
    @olkasu, we have also tested the last attached sample in your suggested environment but it is working fine there too.
    Prabhat sharma.
