Problem with setting the .Text Property of Text field in VB Script
Posted by: korbif on 22 December 2022, 3:57 am EST
    Posted 22 December 2022, 3:57 am EST - Updated 22 December 2022, 4:04 am EST
    i have currently a problem with setting the .Text Property of a Text Field in VB Script.
    I try to set the .Text Property with a single char “-” (Pic #1), but i get a exception during rendering (Pic #2)
    I already tried to set the “-” char with the Char(x) function (Pic #3) from VB in order to escape, but without success.
    How can i set “-” to a text field property “.Text”?
    Thank you in advance,
    Korbinian
    Pic #1:
    Pic #2:
    Pic #3:
  • Posted 22 December 2022, 6:28 am EST
    To resolve this issue. Try to add the below VbScript:
    If calcCustomerId.Text=Nothing or calcCustomerId.Text="0" Then
      calcCustomerId.Text = "-"
    EndIf
    Please refer the attached sample report : CustomReport.zip
    Nitin
  • Posted 9 January 2023, 9:50 am EST
    Hello Nitin,
    sorry for the late reply. Unfortunately the solution does not fully work for me.
    The strange thing is, the text field content is set correctly to “-” when the before content was empty or “0” but in the logs i still get the same error “Expression ‘-’: Expression expected. (at line 1, column 1)”.
    Maybe you have a futher idea?
    Korbinian
  • Posted 10 January 2023, 1:19 am EST
    We didn’t face this issue at our end even in the sample provided by us previously. There are no such errors in that sample.
    Could you please provide the small stripped sample replicating this behavior? So, that we can investigate and assist you accordingly.
    Nitin
  • Posted 11 January 2023, 6:52 am EST
    Hi Korbinian,
    just a guess: is the field set to “Calculated = true”? If yes, FlexReport might try to evaluate “-” as an expression.
  • Posted 11 January 2023, 8:59 am EST
    Hello Wolfgang,
    yes the “Calculated” Property is set to TRUE because we are changing the value via VBScript.
    Maybe i have to somehow escape that “-”? Is there some escape character which i have to put before the “-”? Any idea?
    korbinian
  • Posted 11 January 2023, 11:19 am EST
    Hi everybody,
    the solution was instead of setting my textfield like *.Text = “-”, i must set it to *.Text = Char(45).
    As Wolfgang mentioned before, with the Calculated property set to TRUE, it expects to have some expression to be evaluated and not a single char to write as text.
    Thank you all for your help,
    Korbinian
