Problems with cascade filters on C1TrueDBGrid
Posted by: andreapiselli on 12 November 2017, 1:58 pm EST
    Posted 12 November 2017, 1:58 pm EST
    I’m using the latest version of ComponentOne Studio NET2 (version 4.0.20173.282).
    C1TrueDBGrid behave in a bad way using filters:
    1. When filtering on a colum, on the other filter colunms I should see only the remaining values, as it happens on Excel. The check/unched info is not useful when You have many values.
    2. Even accepting the unacceptable situation on point 1, when filtering on a colum, the columns WITHOUT valueitems “correctly” shows checked only the corresponding filtered values but the problem is that columns WITH valueitems wrongly shows all the values checked.
    3. Applying more than one filter on different columns create even more strange situation on columns WITH valueitems.
    The only solution should be to let C1TrueDBGrid act as Excel do.
    See attached sample project, picture and Excel sample.
    Thanks in advance
    Andrea Piselli C1TrueDBGrid_Cascade_Filter.zipExcel Cascade Filters.zip
  • Posted 1 December 2017, 1:11 am EST
    For first, I have escalated this to our development team as an enhancement request(Tracking ID 299042).
    For second and third, I have escalated the issues to the developers as bug(Tracking ID 299041).
    Will inform you once get any information from them.
  • Posted 16 March 2018, 7:37 am EST
    We are happy to let you know that both the issues ID:299041 & 299042 have been fixed. You can either use C1Live to update or use the following URL to download the new build: http://prerelease.componentone.com/dotnet40/c1winforms/2018-t1/C1WinForms.4_4.0.20181.296.zip
    Ruchir Agarwal
