Question about Zoom Policy
Posted by: mcecconi on 18 January 2019, 11:59 am EST
    Posted 18 January 2019, 11:59 am EST
    Hello everyone,
    I’m having some problems trying to manage the Zoom Policy.
    I created a WinForm application using VB.NET and using C1.Win.TouchToolKit. Some forms contains a ZoomPanel and inside it an C1InputPanel, hosting some InputTextBox, InputMaskedTextBox, InputNumericBox, etc. Now I need to set how zoom function act on theese controls. Please let me know I can do.
    Best regards,
    Marcello Cecconi
  • Posted 21 January 2019, 8:07 am EST
    Hello Marcello,
    Performing Zoom on C1InputPanel and its child controls is very easy using C1TouchToolKit. You just need to drag drop C1ZoomPanel over form and drop C1InputPanel over it. Then, just add items to the dropped C1InputPanel and run the application without making any modifications. You may even take help on how to use C1ZoomPanel from here:https://help.grapecity.com/componentone/NetHelp/c1touchtoolkit/webframe.html#ZoomPanelAddingtoExplorer.html
    Or Is it that you are facing any issue anywhere?
    Ruchir
  • Posted 21 January 2019, 11:21 am EST
    Hello Ruchir,
    many thanks for your reply.
    I’ve done all you mention, without facing any problem, but, as I tried to explain in my original post, the result of zooming is not completely satisfactory for some InputControl. Therefor I would like to change the behavior of the C1ZoomPanel applying customized ZoomPolicy (if it is possible).
    Many, many thaks!
    Marcello
  • Posted 22 January 2019, 9:24 am EST
    I have created a custom zoom policy for the C1Inputpanel. Please refer to the attached sample.
    c1InputPanel.zip
  • Posted 22 January 2019, 1:55 pm EST
    Hello Mohit,
    I just taken a look to your sample.
    It’s exactly what I expected.
    Thank you very much!
    Marcello
