Remove sorting of a flexgrid
Posted by: m-merciersynelia-fr on 27 September 2017, 9:07 pm EST
    Posted 27 September 2017, 9:07 pm EST
    I have a flexgrid, wich has the AllowSorting property true. Every column of the flexgrid also have the AllowSorting property true.
    When i click on a column header, the column is sorted. OK, it’s normal.
    In my flexgrid, the user is allowed to update values, so my problem is that when a column is sorted, and a value is updated, the flexgrid sorts itself instantanately.
    I would like to be able to remove sorting informations of the flexgrid. I tried to use _flex.AllowSorting = false in the keydown event of the flexgrid, but it doesn’t work. As soon as i leave the cell, the flexgrid sorts itself again.
    Do you have an idea to solve my problem ?
  • Posted 27 September 2017, 9:07 pm EST
    In bound mode sorting is done automatically after list changes. This is why when any update is performed sorting is done automatically. This is a .NET behavior. In order for us to have a behavior where sorting is done only on request and that too in bound mode. We would have to create a custom DataSource. Thus we have following requirements from our DataSource:
    1. List should be sortable for every items.
    2. List should not sort when list changes.
    Here is our custom DataSource:
    SortableBindingList
    [csharp]
    using System;
    using System.Collections.Generic;
    using System.ComponentModel;
    using System.Linq;
    public class SortableBindingList : BindingList
    private bool isSortedValue;
    ListSortDirection sortDirectionValue;
    PropertyDescriptor sortPropertyValue;
    public SortableBindingList()
    public SortableBindingList(IList<T> list)
        foreach (object o in list)
            this.Add((T)o);
    protected override void ApplySortCore(PropertyDescriptor prop,
        ListSortDirection direction)
        Type interfaceType = prop.PropertyType.GetInterface("IComparable");
        if (interfaceType == null && prop.PropertyType.IsValueType)
            Type underlyingType = Nullable.GetUnderlyingType(prop.PropertyType);
            if (underlyingType != null)
                interfaceType = underlyingType.GetInterface("IComparable");
        if (interfaceType != null)
            sortPropertyValue = prop;
            sortDirectionValue = direction;
            IEnumerable<T> query = base.Items;
            if (direction == ListSortDirection.Ascending)
                query = query.OrderBy(i => prop.GetValue(i));
            else
                query = query.OrderByDescending(i => prop.GetValue(i));
            int newIndex = 0;
            foreach (object item in query)
                this.Items[newIndex] = (T)item;
                newIndex++;
            isSortedValue = true;
            this.OnListChanged(new ListChangedEventArgs(ListChangedType.Reset, -1));
        else
            throw new NotSupportedException("Cannot sort by " + prop.Name +
                ". This" + prop.PropertyType.ToString() +
                " does not implement IComparable");
    protected override PropertyDescriptor SortPropertyCore
        get { return sortPropertyValue; }
    protected override ListSortDirection SortDirectionCore
        get { return sortDirectionValue; }
    protected override bool SupportsSortingCore
        get { return true; }
    protected override bool IsSortedCore
        get { return isSortedValue; }
    protected override void OnListChanged(ListChangedEventArgs e)
        base.OnListChanged(e);
        // Do not sort the list
    }[/csharp]
    Please find the attached sample with complete implementation.
    ~nilay
    2016/11/RemoveSortingOfAFlexgrid.zip
  • Posted 30 January 2019, 6:03 am EST
    I have the same problem
    but I bound datatable to the flexGrid
    So I can’t use the SortableBindingList
    Do you have please another idea for me?
    Yonit
