Posted 30 October 2019, 4:57 am EST
Good Morning
Is it possible to implement a shotkey on a RibbonTextBox?
This would be the fastest way to move the mousepointer into the text box
Thanks and Regards
João Faria
Posted by: jfaria.blosis on 30 October 2019, 4:57 am EST
Good Morning
Thanks and Regards
João Faria
Posted 30 October 2019, 6:36 am EST
Hi João,
You can use the KeyTip property for this.
Assuming that your textbox (ribbonTextBox1) is in a tab ‘ribbonTabHome’, you can use this:
ribbonTabHome.KeyTip = "H";
ribbonTextBox1.KeyTip = "T";
Pressing ‘Alt + H + T’ will put the focus on the textbox.
Jitender
Posted 30 October 2019, 6:57 am EST - Updated 4 October 2022, 12:36 am EST
Thanks Jitender
As you can see from the image below, i have:
c1.win.c1ribbon.c1ribbon
c1.win.c1ribbon.RibbonTab
c1.win.c1ribbon.RibbonGroup
c1.win.c1ribbon.RibbonTextBox
What is the best and fastest way to reach the textBox via the keyboard??
i do not seem to be able to solve this problem.
Thanks and Regards
Joao Faria
Posted 30 October 2019, 7:08 am EST
Have you tried setting KeyTip property?
In your case, you can right-click on ‘Escalas’ tab, click on ‘Properties’ from the context menu. In the Properties window set KeyTip property (for example, ‘E’).
Similarly, do the same for the textbox.
Also, make sure that SupportsKeyTips of C1Ribbon is set to true.
You can see the attached sample for an example.
After executing the sample, the key combination ‘Alt + H + T’ would focus the textbox.
Jitender
