Posted 20 February 2025, 3:37 pm EST
C1.Win.Ribbon.4.8
VB
Add a text box to the ribbon, bind the label property of the control to a setting in your application.settings. If you then change that setting elsewhere in the application, the UI does not reflect the changed setting. You have to restart the application for the changes to show in the UI. (This may be true for other controls in the ribbon as well)
