Series Axes not positioning properly in FlexChart
Posted by: robert.reinke on 15 July 2025, 9:50 am EST
    Posted 15 July 2025, 9:50 am EST - Updated 15 July 2025, 9:55 am EST
    I am trying to create a rather complex chart based on a design by engineers. Attachment 1 shows how the final chart should look. Attachment 2 shows a preliminary version with details about the axes.
    The chart is a fairly simple line chart except that it requires two sets of series, plotted on different axes: the first series set is plotted on the standard X and Y axes and the second series set is plotted on a second X axis (which is vertical on the right) and a secondary Y axis (which is horizontal on the top).
    The first series, if I do it alone, plots just fine. When I add the second series with new Axes I create and position, the axes do not show up where I position them (right and top) but instead show up top and left and the additional series doesn’t plot at all. Attachment 3 below shows how it turns out.
    This seems like it should work, but is not working at all. Sample code attached. I have spent two days trying different things to make this work, with no success. Please help!
    Bob Reinke
    C1FlexChartDFProblem.zip
  • Posted 16 July 2025, 2:19 am EST
    Hello Bob,
    Thank you for sharing the sample. We have made three changes to your sample:
    1. Do not reverse secondaryHorizontal (Passes) [line: 219] => so that chart look like the image you shared and data is plotted correctly
    2. Reverse secondary series bindings [line: 259] => bindings/axes need to be reversed since the secondary plot is inversed.
    3. Reverse secondary series Axes [line: 268] => same as (2)
    Sample: C1FlexChartDFProblem_Fixed.zip
    In the sample, if references are not resolved, please re-add them.
    Uttkarsh.
  • Posted 16 July 2025, 5:55 am EST
    That worked! Thank you very much!
