set_ColComboList : It takes a long time for the ComboBox to open
Posted by: samo3889 on 14 January 2018, 6:31 am EST
    Posted 14 January 2018, 6:31 am EST
    Hi all :slight_smile:
    When I use set_ColComboList with lots of data It takes a long time for the ComboBox to open.
    There are suggestions how can I improve the Performance ?
    look at the following example : ‘ExampleOfComboList.zip’
    thanks,
    saleem.
  • Posted 15 January 2018, 4:08 am EST
    sorry i forget to attach the file : ExampleOfComboList.zip
    thanks.
  • Posted 15 January 2018, 5:02 am EST
    Hi Saleem!
    I can see the said issue with the sample that you have shared. Hence, it has been escalated to the development team [Internal ID : 305016].
    I’ll inform you once there is any information from them.
    Best regards,
    Meenakshi
  • Posted 18 January 2018, 4:40 am EST
    Hi!
    As per the team, this is a limitation in the control. And, there is no workaround to deal with this as of now.
    Best regards,
    Meenakshi
