Set_row exception
Posted by: roeikup on 19 December 2017, 8:49 am EST
    Posted 19 December 2017, 8:49 am EST
    we using c1 component in c#.
    we are trying to use set_row_position by pressing an ‘up’ button and a ‘down’ button.
    but it’s always throw an exception (like the one is attached).
    the rows the we want to move or set to a new position is connected to a data set, maybe its connected somehow. i tried to do some test in some small project and it’s seem to work fine, that’s why i don’t understand the problem.
  • Posted 21 December 2017, 12:20 am EST
    If you are using C1FlexGridClassis, please notes the below points:
    1. set_RowPosition() method only works for unbound grid.
    2. If you want to implement the move row functionality with data-bound grid then you need to implement it on C1FlexGridClassic’s data source.
    Find the attached sample for complete implementation when C1FlexGridClassic uses DataTable as DataSource.
    Singh
    FlexClassis.zip
  • Posted 26 December 2017, 10:06 am EST
    Thanks!.. this helps a lot…
