Setting panels size in C1SplitContainer
Posted by: carlos.taracena on 15 May 2018, 6:08 am EST
  • Posted 15 May 2018, 6:08 am EST
    I have a problem setting the size of the individual panels inside a C1SplitContainer at design time with the new version 4.0.20181.303. When I set the property Height of the panel, the designer overrides it.
    I noticed that there is a new property AutoSizeElement that does nor show in the properties window but is assigned in the designer.cs file. It is set to C1.Framework.AutoSizeElement.Both by default. I tried setting it to C1.Framework.AutoSizeElement.None, but it does not work.
    Is there anything I have to set up differently now? What am I missing?
    It used to work correctly in previous versions.
    I’m using VisualStudio 2017 and Studio for WinForms 4.0.20181.303.
