Posted 8 October 2019, 9:14 am EST
Is there any way to control the color of the tooltips that pop up?
Posted by: mike on 8 October 2019, 9:14 am EST
Posted 9 October 2019, 3:20 am EST
Hi Mike,
basically, it should be possible. It seems the grid uses a label to display the tooltip. But unfortunately, this is all internal API.
Attached is a sample which shows a proof of concept. I used ILSpy to analyze the C1FlexGrid internals. The sample makes heavy use of reflection, and I have to access a property which has an obfuscated name - thus the sample might not work with other versions than .382.
Maybe the C1 guys can add some public API to access the tooltip control.
Posted 9 October 2019, 6:48 am EST
The solution suggested by @Wolfgang seems to be the only solution for now because it is directly not possible to access that tooltip.
@Wolfgang, thank you for the explanation and the sample.
Posted 10 October 2019, 12:30 am EST
Thanks lots. Will use that for now, stuck in exception handling in case it breaks on later versions.
