Sort String As Number in C1FlexGrid in runtime
Posted by: hanthuong847742 on 9 October 2023, 11:23 pm EST
    Posted 9 October 2023, 11:23 pm EST
    Hi, I have problem when migrate from ComponentOne VSFlexGrid 8.0 to ComponentOne C1FlexGrid.
    In VSFlexGrid 8.0 have property flexSortNumericAscending to sort column like a number even if I set DataType of this column to String in form load
    But in C1FlexGrid does not have this property. So I tried it in two ways:
    1: In BeforeSort event I change data type of this Int32: C1FlexGrid1.Cols(e.Col).DataType = GetType(Int32).
    But it not working. It only work when I clear all data in all cell and rewrite it.
    2: I create a Custom Sorting and using it in before sort event but it also not working:
    Private Sub C1FlexGrid2_BeforeSort(sender As Object, e As SortColEventArgs) Handles C1FlexGrid2.BeforeSort
    		C1FlexGrid1.Sort(New FileNameComparer(C1FlexGrid2, e.Order))
    	End Sub
    Public Class FileNameComparer
    	Implements IComparer
    	Private c1FlexGrid1 As C1FlexGrid
    	Private _desc As Boolean
    	Public Sub New(ByVal flex As C1FlexGrid, ByVal order As SortFlags)
    		c1FlexGrid1 = flex
    		_desc = ((order And SortFlags.Descending) <> 0)
    	End Sub
    	Public Function Compare(r1 As Object, r2 As Object) As Integer Implements IComparer.Compare
    		Dim s1 As Integer
    		Integer.TryParse(c1FlexGrid1((TryCast(r1, Row)).Index, 1), s1)
    		Dim s2 As Integer
    		Integer.TryParse(c1FlexGrid1((TryCast(r2, Row)).Index, 1), s2)
    		Dim icmp As Integer = If(s1 > s2, 1, 0)
    		Return If((_desc), -icmp, icmp)
    	End Function
    End Class
    How can I configure the same side as vsflexgrid8. Can you give me some suggestions? Thanks (Note in my case: In form load event I set all data type of all column in grid to String type)
  • Posted 10 October 2023, 3:44 am EST
    I think your second approach is the way to go. Only one line is missing: set “e.Handled = true” to prevent the grid from doing the default sorting:
    		e.Handled = true
    	End Sub
    Hope this helps
  • Posted 10 October 2023, 4:51 am EST
    It’s working!!! Thanks you very much Wolfgang.
