Sorting a C1TrueDBGrid
Posted by: beheerder on 9 August 2018, 8:43 am EST
    Posted 9 August 2018, 8:43 am EST
    If have a C1TrueDBGrid bound to a datasource (typed datatable), which contains a SortOrder column. This way, the user can change the order of the rows.
    When the user moves a row up or down, i just change the number in the datatable SortOrder column programmatically.
    This works ok, but now i have to reorder the data without re-filling the datasource.
    In a C1Flexgrid i just call the .Sort Method to re-order on a specific column.
    How can i do this in a C1TrueDBGrid?
  • Posted 9 August 2018, 8:46 am EST
    By the way, i am using VB.NET
  • Posted 10 August 2018, 6:48 am EST
    TrueDBGrid does not have programmatic sorting like FlexGrid. You would need to modify the DataSource for applying a sort order.
    However, if you only need simple sort then you can take the DataTable’s DataView and set an appropriate Sort property to apply sorting on a column.
    You can refer to the attached sample to see an example.
    SortTrueDBGridVB.zip
  • Posted 10 August 2018, 8:54 am EST
    Thanks for the quick response. I will give it a try.
    Kind regards,
    Willy
