Split Panel Headers visible when collapsed
Posted by: gharshman on 14 February 2018, 2:38 pm EST
    Posted 14 February 2018, 2:38 pm EST
    Is there a way to make the headers on the split panels in the split container visible when the panel is collapsed? Three screen shots are attached: what is looks like expanded, collapsed and finally what it would ideally look like.
    Thank you
  • Posted 14 February 2018, 2:40 pm EST
    Collapsed
    Ideally
  • Posted 15 February 2018, 6:37 am EST
    Though, there is no direct way to do that, the following workaround using MinHeight, Visible properties and VisibleChanged event, can be used to meet your requirement:
    Boolean flag = false;
            private void c1SplitterPanel3_VisibleChanged(object sender, EventArgs e)
                if(c1SplitterPanel3.Visible== false && !flag )
                    flag = true;
                    ShowHeader();
                if (c1SplitterPanel3.Visible == false && flag)
                    flag = false;
                    Default();
            public void ShowHeader()
                c1SplitterPanel3.Visible = !c1SplitterPanel3.Visible;
                c1SplitterPanel3.Height = c1SplitterPanel3.MinHeight = 25;
            public void Default()
                c1SplitterPanel3.Height = 90;
    Ruchir Agarwal
    C1Split_Header.zip
