Spread WF, #REF trying to copy/clone sheet
Posted by: epena on 30 August 2021, 9:45 am EST
  • Posted 30 August 2021, 9:45 am EST
    Having two spreads, spread1 with desired sheets to copy, spread2 the one about to receive a copied/cloned sheets version from spread1, the sheets contains defined names, the spread2 control shows #REF on formulas using defined names or referencing other sheets. If spread2 is saved as .xls the references work fine in Excel and all defined names are there & working. spread1 shows correctly…
    Tried this code:
            public void CopySheetsToThis(F1BookHelper bookToAttach)
                int thisSheetIndex = base.ActiveSheetIndex;
                try
                    base.Sheets.RemoveAt(base.ActiveSheetIndex);
                    foreach (SheetView sheet in bookToAttach.Sheets)
                        //base.Sheets.Add(CopySheet(sheet));
                        base.Sheets.Add(sheet.Clone());
                catch (Exception ex) { throw; }
                finally
                    this.ActiveSheetIndex = thisSheetIndex;
    Also tried this code:
    http://helpcentral.componentone.com/NetHelp/SpreadNet6/WF/spwin-sheetcopy.html
  • Posted 31 August 2021, 7:57 am EST
    We do not see this issue at our end. Please refer to the sample attached. Could you please share a sample replicating the issue, so that we can investigate this at our end?
    Avnish
    SpreadFromula1.zip
  • Posted 2 September 2021, 10:00 am EST
    Hi Avnish,
    I’ve attached back the code sample you sent me and a capture of the #REF errors I’m getting.
    Changes I did:
    -In VS Designer, on fpSpread1 → Spread Designer
    Go to Sheet2:
    -Cell $B$2: Add a define name (myDefineName).
    -Cell $B$4: Set value 7 then added a define name (mySeven).
    Go to Sheet1:
    -Cell $B$6: Set formula ‘=myDefineName3’
    -Cell $B$8: Set formula '=mySeven
    3’
    On startup fpspread does have the calculations done, when Copy is clicked, fpSpread2 shows the #REF.
    I’m missing something with the copy procedure?
    Eduardo
    SpreadFromula1.zip
  • Posted 3 September 2021, 12:15 am EST
    We have reported this issue to the development team and will let you know when we have an update.
    Avnish
    [Internal Tracking Id: SPNET-20211]
  • Posted 3 September 2021, 9:56 am EST
    Hi Avnish,
    Thanks for reply, is there any estimation of time before we have any news of the issue, or at least a minimum wait time for development team to take the case?
    Eduardo
  • Posted 6 September 2021, 1:34 am EST
    Hi Eduardo,
    As per the development team, When the sheet view is added to spread, the spread will invoke the LoadFormula, so you need to use the BeginInit/EndInit to suspend/resume the load formula at the end. So that the formulas are loaded when all the sheets are copied.
    Avnish
    SpreadFromula1_nod.zip
  • Posted 6 September 2021, 1:22 pm EST
    Hi Avnish,
    I’ve tested the Begin/EndInit as the example, so far so good.
    Thanks for the help.
