Suggestion: "Partial" RadialMenu Enhancement
Posted by: fabio.lavitola on 13 August 2022, 8:28 am EST
  • Posted 13 August 2022, 8:28 am EST
    it would be nice to have the feature for RibbonMenu to choose the starting and the ending angle (from 0 to 90°, from 90° to 180° and so on).
    At the moment the hypothetical start angle is 0 and the hypothetical end angle is 360°.
    I.e. with a 90° radialmenu, I can show it starting from any angle of the form with only the usable part of the radial menu showned, to avoid a lotta other menus…
    If inserted into a ribbon (as a new RibbonItem) i can also use that partial ribbon in any ribbon menu.
  • Posted 17 August 2022, 2:58 am EST
    First of all, apologies for the delay in response.
    Secondly, we could not clearly understand how you are using the C1RadialMenu in your application. Are you trying to use the C1RadialMenu inside a C1Ribbon?
    Also, could you please share your use case for which you require a partial RadialMenu? This would help us to assist you better.
    Thanks, and Best Regards,
  • Posted 17 August 2022, 4:56 am EST - Updated 3 October 2022, 10:16 pm EST
    HI,
    as “Partial” RadialMenu I mean a radial menu appearing ina corner of a containe (I.E. a form or any other C1 Container).
    I attach 2 pics:
    1. A Standard Radial
    2. A desiderata, in the bottom left corner
    If a Partial radial menu is ativated into this container (I.e.
    C1PartialRadial1.Attach(Me, PartialRadialPositionEnum.LeftBottom)
    inside the containing fomr, I’ll see a portion of a circle in the bottom left corner : the hovering, will show that menu (pic 2)
  • Posted 18 August 2022, 3:40 am EST
    Thank you for the detailed explanation. We are discussing your requirement with the development team to get their insights on it. We will let you know as soon as we have an update.
    [Internal tracking Id: C1WIN-28026]
    Kind Regards,
